new husqvarna 562xp air filter concerns
Discussion in 'Chainsaws and Power Equipment' started by denny461, Dec 19, 2015.
  1. denny461
    denny461
    Scipio, indiana
    Are you still running the saw although you tried both methods to keep the dust out. How long have you been running the saw.
    clemsonfor likes this.
  2. Firewood Bandit
    Firewood Bandit
    Sure I am running them, it's a saw. I don't like it but if it blows there is a 4 year warranty. So run the cr@p out of em before it happens. The 562 is very strong, the 550xpg, not so much.
  3. denny461
    denny461
    Scipio, indiana
    I only got a 2 year. I asked my dealer about it and she said only a 2 year even if I bought the mix.
  4. Oldman47
    Oldman47
    Illinois
    Deal must have changed. I bought my 555 with 3 cans of fuel and got the 4 year warranty earlier this year.
    Firewood Bandit and clemsonfor like this.
  5. clemsonfor
    I understand that but in my mind I think what about all the undue wear I put on it that first 4 years or whatever and it blows up at 6 cause of the issue.
    There is a problem there. If dealer is made aware any damage should be covered. Thats a flaw. If you take a fresh run saw in thats not neglected and dont have a crappy filter and all that dust is in the intake thats a flaw. Think of all that was injested and not stuck in the intake.
    Oldman47 and Horkn like this.
  6. RJames
    RJames
    Have to keep those chains sharp! I used to get the fines but learned that a good sharp chain is your best way to keep the filter clean.
    Big chips can't get by the filter. I was being lazy and working a dull chain too long.
    Chvymn99 and Sunfish like this.
  7. clemsonfor
    That helps a lot. But things like dry wood just make more dust. Sharp chains cut it down but dont eliminate it
    Firewood Bandit likes this.
  8. CoreyB
    CoreyB
    South east iowa
    Surely there is something wrong. Why would they go backwards on a proven design? I would be questioning my dealer real hard. But I cut some old dry dusty crap sometimes
    clemsonfor and Horkn like this.
  9. RJames
    RJames
    Ok then
  10. Firewood Bandit
    Firewood Bandit
    Trust me, I am fairly adept at grinding chain and keeping them sharp.:whistle:
  11. clemsonfor
    I wasnt the one who said your running a dull chain. I pointed out that even sharp chains make some dust.
  12. Firewood Bandit
    Firewood Bandit
    This is not a product of dull chains. Most of the wood I cut is very large, cut offs from log landings on freshly felled logs. It is not dry either. The only dust is the dirt from being skidded, a necessary evil.
  13. Firewood Bandit
    Firewood Bandit
    No offense taken, I get it.
  14. denny461
    denny461
    Scipio, indiana
    Been cutting dead ash trees thanks to the Ashbore worm. I keep my chain's sharp but this dead dry wood make a lot of dust.
    Ronaldo, Chvymn99, Oldman47 and 3 others like this.
  15. Canadian border VT
    Yeah when I cut 3 year old dead ash got a lot of small chips. they tend to dull chain faster then fresh wood. but even freshly sharpened chains still had a lot of dust!
    clemsonfor and Oldman47 like this.
  16. RJames
    RJames
    That's some good burning stuff. Supposedly "warms the kings feet".
    If you have some and want to try it, put a thin layer of dieletric grease around the horn base and around where the filter mounts to it . That grease works very well on my ms261 filter base
    Ronaldo likes this.
  17. denny461
    denny461
    Scipio, indiana
    I put bearing grease that came with the saw around the base of the horn. Also around where the 2 pieces snap together. Cleaned an area inside the intake boot. Next time I cut with it I will check the area I cleaned to see how much is in there.
    Nixon, RJames, Chvymn99 and 1 other person like this.
  18. Firewood Bandit
    Firewood Bandit
    As I said earlier, the grease didn't help, the O ring didn't help and the flocked filter was a replacement for the nylon mesh, (white one) that came with the "G" model. There is a problem with the air horn on these auto tunes.
    This is the saw I have run probably the most, a 346XP, and it has NEVER been cleaned inside the throat. This is also the OLDEST (in regards to how long I have had them) saw I have other than the Stihl.
    Sunfish, clemsonfor and RJames like this.
  19. clemsonfor
    Yea I dont clean carb throats and have almost no dust ever in them. I would freak out if I pulled the filter on my new saw and saw that in there!!!
  20. RJames
    RJames
    Are you thinking that it's getting through the media? Seems you've sealed up all the other points of entry.
