New Here
Discussion in 'The Wood Pile' started by MHL68, Feb 12, 2025.
  1. Holland Dell
    Holland Dell
    SW Wisconsin
    Welcome to the rabbit hole,
    I suspect you have plenty of dead Ash in your area being in southern Minnesota. If not on your own property, perhaps scrounge a little. Ash makes great stack starters to get you to a 2-3 year supply. It dries quickly when stacked and burns pretty hot. If you don't know what a dead Ash looks like, find someone that does. Once you see one, you won't be able to un-see them. Use more caution when dropping them and watch some videos. Ash has a lot of fragile top branches that can get you. You'll realize how fragile they are the first time you drop one and the top explodes everywhere.
    FYI- you'll need at least 10 good saws. :rofl: :lol:
    Good luck
  2. brenndatomu
    That's the budget starter kit...:D
  3. metalcuttr
    metalcuttr
    western WA
    Hey MHL68 , glad you dropped by! Pull up a stump and grab a cup of coffee. Lots of characters to learn from here! I live in Washington State and Lopi is a well respected name up here, I'm sure you will enjoy yours. Sounds like you have and are acquiring some good equipment although you need to work on more saws. Concerning wood, when I first started, close and free was the name of the game. As your hoard and experience grows you will learn to be more selective. You will become adept at sniffing out scores and develop connections with land owners and tree services and such. I have a cadre of friends who are always on the lookout for potential scores. It is all a learning process and an enjoyable and rewarding one at that! I am looking forward to your posts and pictures. Again, Welcome!
    T.Jeff Veal, John D, Chud and 2 others like this.
  4. Monkeysocks
    Monkeysocks
    SE Minnesota
    All the counties south of the metro are in the EAB quarantine zone and Rice county definitely has it, so you’re not likely to spread it worse by moving ash. I’m in Cannon Falls and scrounge mostly Dakota, Goodhue, and Rice county.
    We probably have some overlap in the areas we’re looking for wood. There a lot of stuff in the Northfield and Kenyon areas.
    FB marketplace usually has a decent amount of wood available around Faribault, and if you’re willing to drive a little farther, there is always a lot in the south metro.
    I like to keep my cutting gear ready to go in the summer because after a July thunderstorm, you’ll have more opportunities than you can handle.
    MNWood, Chud, T.Jeff Veal and 4 others like this.
  5. brenndatomu
    EAB quarantine is a waste of time, it hasn't worked anywhere yet, just delays the inevitable a bit, end result is they all dead, except for the few that seem resistant.
    isaaccarlson, Chaz, Chud and 6 others like this.
  6. yooperdave
    :handshake:
    Chaz, T.Jeff Veal, John D and 2 others like this.
  7. yooperdave
    While on a snowshoe walk, I noticed some 8" ash trees along property line that have the bark beginning to peel off. Looks like I'll be re-prioritizing my ash tree removal to that spot this spring.
    Chud, T.Jeff Veal, John D and 3 others like this.
  8. MHL68
    MHL68
    Southern MN
    That is good info about the counties South of TC. I work in Lakeville and my current score is in Burnsville a few minutes away. Guess I'm not hurting anything bringing it south.
    I have noticed some in the Northfield/Kenyon area. Wife works in Northfield...if I could only get her to load 50lbs logs after work I'd be golden!! :rofl: :lol: I'm going to have to infect her with this hording disease I have caught. Don't think that's going to happen.
    MNWood, Chaz, JD Guy and 8 others like this.
  9. MNWood
    MNWood
    Coon Rapids Minnesota
    Welcome to the Club!
    I live in Coon Rapids. The family also owns land east of Mille Lacs. I will bring firewood from up north home but not the other direction. EAB will get up there soon enough regardless but I don't want to speed it up. When all of our Black Ash trees up north are gone it will be very sad.
    Working in Lakeville, between work and home you should be able to find more free firewood that you will soon have room to store. Then you can become more picky about what you take. I don't resell any so now having more than 3 years cut, split and stacked I pass up any that I can't load right into my trailer. At 62 I'm not wheelbarrowing wood 100 yards across a yard just to get more free wood.
    I can nearly heat my house with a Travis industries fireplace Insert. If I'm diligent about reloading and whatnot our force air furnace doesn't call for heat. The downside is we have a walk out and the fireplace is on the main floor so the lower level can get cold if the furnace doesn't run for days. Lowest I have seen down there I think is 58 while upstairs is like 70.
    We had a Beagle for many years. I think they are the best.
    I would love to live on a lake if the fishing is even halfway decent.
    Don't forget we like to see photos. Post photos of your fireplace, wood pile, loaded truck whatever. :)
    John D, Chud, T.Jeff Veal and 4 others like this.
  10. isaaccarlson
    isaaccarlson
    Colfax, WI
    There’s more wood around the area than you can shake a stick at.
