New guy with a couple questions.
Discussion in 'Modern EPA Stoves and Fireplaces' started by reprod, Jan 2, 2017.
  1. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Woodstock uses ABF Freight. I payed $328 I believe, to have one shipped to Western Wi, so all the way across the country for $600 sounds about right. Air seal and insulate like crazy! I kept an eye on my build while it was happening and my builder was air sealing where I never would have thought about doing it. Every floor or ceiling penetration of wires, pipes, etc. at least got a shot of great stuff around it. All the inner plastic vapor barrier also got a bead of caulk around the outside perimeter of each run! I was amazed at how tight it got sealed up.
    papadave, fox9988, reprod and 2 others like this.
  2. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I hope you have some sort of a exchange system... being too sealed up causes health and moisture problems.....
  3. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Yes there is plenty of ventilation where its needed/supposed to be. Fresh air supply to the furnace room, attic ridge venting, etc. Its all code stuff now for energy efficiency to save on fossil fuels ya know. I do understand it can be too tight.
    HDRock, reprod and Backwoods Savage like this.
  4. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    look into an energy recovery ventI later if you start having high humidity or stuffy air....
  5. Backwoods Savage
    Just be careful if you find dealers doing the foam. After we did ours I found another fellow, Pallet Pete who was going to do the same thing but the quotes he had from a couple others were way out of the ballpark. So I sent the dealer we had to him and Pete saved a few thousand dollars! We sent him to a few other places too and I've never had any negative feedback. This makes me happy.
  6. reprod
    reprod
    Pacific NW
    Thanks for the advice about the foam installers. I am meeting with the our builder tonight. This will be one of the subjects discussed.
    The area we are relocating has some very high electric rates. So I have been exploring different ideas about efficiency, cost savings with this in mind. It is a never ending rabbit hole.
    I talked with one of our local hvac guys last week regarding air flow with the "tight" house. We discussed ERV, heat pump, geo thermal heat pump, etc. I am keeping all options open. He was leaning towards heat pump/air handler to move the air. I haven't had the best of luck with our heat pump. This house we are in now is the first house we have used one in. We've had a guy out to work on it every year averaging about $200/yr.. We finally had to replace it this year, it was only 9 years old. Probably a lemon, but many people I know have problems with them. They are nice for keeping the house comfortable in the "shoulder" season and summer.
    Backwoods Savage, Eric VW and fox9988 like this.
  7. reprod
    reprod
    Pacific NW
    Forgot to mention the most important part. I am no longer leaning toward the Woodstock Ideal Steel, I am in the expecting delivery category now. I put down a deposit, its gonna happen in a few weeks. I'm excited for the stove and to put one decision behind me.
  8. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Before you consider a stove consider insulation it may be a real $$$ saver and prove far better in the long run.
    I will atttest to its quality. Spray foam has drawbacks like anything else however it's proven to be the best investment we could have made. The drawback that annoys me the most is if I need to get into a wall it's very fragile and you pretty much have to consider that section of insulation forfit however the insulation factor is insane! Our home used to use 2 8000btu window air units in the summer on full blast to be comfy on really hot days... Now we use one 5000 btu unit in energy saver mode and keep the entire downstairs cool.
    Wood stove difference is equally as impressive. We historically have had 2500 sq ft stoves to be comfy and would need to run full blast in the cold weather. After the insulation I havnt run a full box very often and defiantly don't load half as much. We load twice a day in the bitter cold weather ( -30 wind chills ) and in the normal winter ( -7 range ) we load 3 half loads on average.
    Now to be fair we also use pellets however that's mainly on very cold windy nights just far an extra warm boost for the wife due to health issues. We honestly don't need pellets it's just a nice addition.
    Wood consumption has plummeted! 8 to 10 cord avg in our old US Stove wonderwood before insulation Jotul F50 before insulation was 5 cord avg and after insulation we use about 3.5 full cord if we run full time all winter.
    Insulation is defiantly where we should have started years ago no question but the first stove was free. Live and learn I suppose.
    Now the other side of the coin Firewood is NOT cheap it IS warm. You will spend money on equipment like saws, log cants, chains, files, saw bars, safety gear, axes and other things not to meantion the stove or in some of our cases stoves and maybe even a log splitter and a vehicle to transport it.
    My point is yes I love wood heat obviously ( FHC :whistle:) but it is very much a way of life for most of us. I like the smell of AV gas, I like the smell of my old wood hauler, I like the smell of the wood and so on we would not have it any other way bit if I did it all again I would definitely have insulated first knowing what I know now. You know! :D
    We would still have wood stoves though it's just what we like. There is nothing warmer in my opinion but it's wasted heat without insulation..
  9. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    Sconnie, I was going to ask you what the freight was to our part of the country. I doubt you could drive out to pick it up for that.
    Remember all, " Insulate tight and ventilate right". I just signed up for my continuing education class on, " New advances in Foam Technologies". Feb. 21st.
  10. reprod
    reprod
    Pacific NW
    I will be interested to hear what you learn. I talked with the builder tonight. He echoed some of the "cons" as mentioned above. The biggest being the permanence of sealing the wall for future stuff, routing wires, etc. He hasn't done a house with spray foam since 2005. It was about 2x the cost back then. I am going to be researching it more, but like I said... it isn't too common out here. I will be curious to see why.
  11. Eric VW
    You could see about adding some type of "chase" or unoccupied conduit for future expansion? May not be easy, but would allow for critical future needs....
  12. bushpilot
    bushpilot
    Eastern Washington
    If you want to compromise, do flash and batt.
    www.greenbuildingadvisor.com/blogs/dept/guest-blogs/flash-and-batt-method
    It has most of the pros of foam, at a little less cost, andyou still have room for the future routing.
  13. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    Greg,
    Great points and great article for making your point. I am also a fan on that technique in the ceiling. Fills all the tiny little penetrations that can be missed. I then use cellulose as the top fill layer. Again, I can float in all the cavities that make for a quality job.
    Another thought would be to build in a wiring/plumbing chase in an adjacent interior wall.
  14. Ashwatcher
    Ashwatcher
    West By God Viginia
    Welcome reprod You're gonna like it here, I guarantee it! Interesting that my home and yours are nearly identical. My great room peak is at 23', same sq. ft., etc. Insulation and all the other points of significance as pointed out by my brethren notwithstanding, ceiling fans are so very critical. I placed 2 90# Hunter Originals on 6' downrods in the great room splitting the vaulted ceiling as they should be roughly 9-12' off the floor and 1 of the same on a 3' downrod centered over the loft bedroom. I have found my best combo of usage is to of course have the one upstairs pushing down and those in the great room rotating opposite one another. Makes for a great air circulation/heat distribution in my set-up. Just food for thought.
    Again, welcome to the hood and nice to meet ya! :handshake:
  15. reprod
    reprod
    Pacific NW
    Nice to meet you as well.
    Great to hear you have a similar place.
    I will look at those fans for sure. I was envisioning 2 pretty large fans. Great to have a size/model to reference.
    Out of curiosity... Do you have any additional air circulation (duct work, etc)?
    Thanks again to everybody for the great info.
  16. brenndatomu
    Backwoods Savage and Eric VW like this.
  17. Eric VW
  18. brenndatomu
    It was going to be about half again more than foam...the guy that did my foam job may have been a little cheaper than average though too...
  19. Ashwatcher
    Ashwatcher
    West By God Viginia
    I have a gas furnace and accompanying duct work in the crawl space underneath the house serving the first floor and took the duct work up the inside garage wall to the upstairs with two vents wall mounted towards loft bedroom and some flexible duct heating the storage space over the 24x24 garage-The gas heat never runs!!!! I hate it and my gas bill, (I cook with gas) is the minimum $10.10 per month---Call me a crazy wood hoarder anyone???? The fans are simply Hunter Originals-you add oil one time,,,they have been up 11 yrs now, not a sound from them
    reprod, papadave and Backwoods Savage like this.
  20. Woody Stover
    Woody Stover
    Southern IN
    Good move. From my experience with the Woodstock stoves, I'd be hard-pressed to switch brands....the quality I've seen is that good. You got the ash pan, right? If not, call 'em back and add it, quick! :cool: I've been hooked on grated ash-handling since I got the Dutchwest...never going back if I can help it....it's that much cleaner and easier. Now, I've heard the IS grate slots may be a little narrow compared to their other stoves, and it takes more passes with the poker to work the ashes down. I wonder if anyone has yet tried widening the slots a little, or is there some reason Woodstock designed this grate differently?
