New Fahrenheit Endurance owner, a couple questions
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by ZachGrant, Jan 19, 2015.
  1. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Huh, how much is that stuff?
    ivanhoe likes this.
  2. ZachGrant
    ZachGrant
    South Dakota
    Free-99... Got 3000 bushel from a neighbor for nothing. It's not worth anything once the bugs get in it.
    ivanhoe likes this.
  3. eatonpcat
    Wow...10-15 # an hour.
    ivanhoe likes this.
  4. DexterDay
    DexterDay Administrator
    Northeast Oh
    I question this as well..
    The hopper has a rated "capacity" but his Grain is probably very light weight and also small, which means a very good feed rate and a fully packed auger.
    10 lbs an hour? That's 240 lbs a day (or 2 full hoppers! This hopper is pretty big)
    I burn roughly a bag a day, but I also burn wood majority of the time. I don't have a wood fire currently because of warmer temps. But tomorrow the wood stove will be lit.
    ivanhoe likes this.
  5. ZachGrant
    ZachGrant
    South Dakota
    Keep in mind also that a bushel of wheat weighs 60 pounds. I'm probably getting closer to 140-150 pounds in the hopper. But yeah it burns a little over a half a day on a hopper... Although I haven't actually timed it and kept track.
    ivanhoe and eatonpcat like this.
  6. DexterDay
    Northeast Oh
    I didn't think that a bushel of grain was heavier than a bushel of corn..
    So that makes sense. It's probably closer to 140 like you said.
    Half a hopper is about 70-75 then. If you're running 24/7 on level 3, then it's just over 3 lbs an hour.
    ivanhoe likes this.
  7. ZachGrant
    ZachGrant
    South Dakota
    I'm burning about a hopper every 13 to 14 hours. Although as of late I haven't even been running it because we've been having an onslaught of 50 to 60 degree days here
  8. DexterDay
    Northeast Oh
    :bug:
    Wow!! 2 full hoppers!! Yeah, that's a lot!!
  9. ZachGrant
    ZachGrant
    South Dakota
    but now that I think of it I might have been on level 4 & 5 for quite a bit of that. I turned it down to level 3 when I was leaving overnight though.
    ivanhoe, DexterDay and eatonpcat like this.
  10. DexterDay
    Northeast Oh
    I'm at about a bag a day.
    What fuel setting are you using?
    The lower you go from Premium pellet (#10), the sooner it autocleans. When it autocleans, it ramps up to level 5 for 30 minutes and burns a lot of pellets.
    Maybe try going up a setting or two. No need to clean the pot every 4 hrs, if it can make it 8 hrs before it needs it.
    Even with a 50/50 mix of corn to pellets I still run #10 (Premium pellet). Because that is the longest interval between cleaning time, and it's only 8-9 hrs.
    ivanhoe likes this.
  11. ZachGrant
    ZachGrant
    South Dakota
    I am burning on fuel setting 3. Wheat actually calls for 2 in the owners manual, but I find that my flame looks much healthier on 3. The often cleaning doesn't bother me much. It would be a different story if I were paying for the fuel I suppose.
    ivanhoe likes this.
  12. ivanhoe
    ivanhoe
    Northern Ontario
    Doing a lot of trials, that's good. I picked up some corn to try, mixing with pellets for now. Nasty cold spell on the way, not a good time to experiment. Lucky for you having all those cheap resources at your disposal. Keep experimenting for us:D
  13. DexterDay
    Northeast Oh
    Flame won't differ from 1 to 10.
    Air flow is dependent on your intake/damper setting
    What differs is how many times it cleans a day. I wish I could make mine go 24 hrs on pellets. But 8-9 is the max.
    I promise you, you can move up at least 1 or 2 settings.... If not more.
    You will use less fuel because of less cleanings. Which will mean you have to load it less.
    ivanhoe likes this.
  14. ZachGrant
    ZachGrant
    South Dakota
    I only have 5 settings, and I'm almost positive that it feeds more fuel on 3 and 4. My flame is noticeably bigger on those settings than any other. Also, here is an excerpt from my owners manual about fuel types. It reads in a way that makes me think there is different feed rates as well.
    ivanhoe likes this.
  15. DexterDay
    Northeast Oh
    You have an older unit, but the principal is the same. It will go longer between cleanings, with a higher setting.
    So if yiu are running on 3? Then a step up to 4 may show a reduction in usage. The more it cleans? The more it will eat fuel as it burns on High (heat level 5) for 30 minutes or better. If it's cleans every 3 or 4 hrs now, you are cleaning 6-8 times a day. If level 4 is about 6-7 hrs, that is around 3-4 times a day. You cut that level 5 time in half.
    The combustion blower is always running the same speed. Your damper is what controls the air, unless the furnace is idling at level 1 (then your trim settings come into play).
    ivanhoe likes this.
  16. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Makes sense, I am running level 4 on the newer unit. It gets the house back up to temp where level 3 just ran and ran and took forever to satisfy the tstat.
    Wondering if I should step up to 5 myself....in theory the house should hit tstat temp faster and less pot changes?
    ivanhoe likes this.
  17. ZachGrant
    ZachGrant
    South Dakota
    For my own sanity I called fahrenheit today and confirmed that the different fuel settings feed different amounts of fuel. The higher the number the more fuel it feeds.
    ivanhoe likes this.
  18. DexterDay
    Northeast Oh
    You are talking about your heat level. I am talking about the fuel selection. No need to run on heat level 5 if 4 is sufficient.
    You are probably running on Premium pellet anyways, so don't change a thing..
    On the older units? Maybe this holds true. I have ran on all of my levels and me out temp at my plenum never changed. The only thing that changed? Is the cleaning cycle. But our furnaces have different control boards and burn pots, so a lot has changed.
    ivanhoe likes this.
  19. ivanhoe
    ivanhoe
    Northern Ontario
    Strange,it should bounce fron 5 & 1 settings in T-stat mode unless the newer units are different all together.
  20. DexterDay
    Northeast Oh
    I think a lot of people are reading things wrong.
    You are correct, but Triple A worded it differently. He is saying that at level 3 the stat never reaches the desired temp. So it runs and runs. Where level 4 he meets desired temp.
    So he thought I was talking about the heat setting, when in fact, I have been talking about fuel setting. So he thought he should go to 5.
    You should only use the highest heat setting necessary to satisfy the stat. Any higher and the room may get to temp faster, but you are heating the house quickly, which means you are not getting a good "soak" temperature. A slightly lower heat setting will run a little longer, but it will heat all the items in the room before the stat is satisfied. Which means the furnace will have a longer break and not work as hard overall.
    ivanhoe likes this.
