  1. DexterDay
    DexterDay Administrator
    Northeast Oh
    I keep getting your thread confused with BAN83.
    My Apologies.
    If it's not connected to the LP furnace? Then I would expect very little (actually none) through your HVAC vents.
    ivanhoe and BAN83 like this.
  2. BAN83
    BAN83
    Ontario, Canada
    Hey Old Fart,
    All these units seem to burn a bit dirty. The real indicator is what colour the inside of the fire box turns. You should see a light brown ash. If you look up my thread on my install you'll see some pics from Dex showing the inside of his fire box. It's super clean burning and is actually more of a grey colour. Here's the link:
    Fahrenheit Endurnace 50F Project | Page 25 | Firewood Hoarders Club
    Go to page 25.
    One thing I see with your build up on the glass is that it is very uniform. Mine only builds up on the one side of the glass as the flame leans way to the one side.
    Also, as The Guys are saying, you've got some tune in time ahead of you.
    DexterDay and ivanhoe like this.
  3. DexterDay
    Northeast Oh
    It took 2 years of tinkering and upgrades (I was the 1st Fahrenheit owner on the last forum we were on) to get it burning well. Then another year of testing... Then the last 2 years were pretty good, until I got that big impeller and motor.. Now it's good to go.
    I loved it from day 1. But it is now my favorite stove ever. My Enerzone upstairs is a bottom feed (like Harman), self troubleshooting, LCD control panel, and great efficiency, but the self cleaning Fahrenheit that keeps my entire home 72-74° on the coldest of days is by far the best unit I've had the pleasure of run
  4. Old Fart from Eganville
    Eganville, Ontario
    Not sure if I know what you mean Dex. But sometimes the old brain gets a little slow.:doh:
    ivanhoe likes this.
  5. Old Fart from Eganville
    Eganville, Ontario
    My furnace guy is coming over this morning so we will see if there is a problem with the return air.
    Thanks all for the answers.
    Old Fart
    BAN83 and ivanhoe like this.
  6. ivanhoe
    ivanhoe
    Northern Ontario
    What Dex is saying, you're not connected to the propane furnace which is connected to the duct works of the house so how are you connected? In your pictures you're connected to something.
    BAN83 likes this.
  7. Old Fart from Eganville
    Eganville, Ontario
    Propane furnace is no longer connected. I moved the duct over to the pellet furnace.
  8. ivanhoe
    ivanhoe
    Northern Ontario
    How many registers in the house? Hot air that is.
    BAN83 likes this.
  9. Old Fart from Eganville
    Eganville, Ontario
    Right now 7. I am going to add 1 or 2 more for the basement. Right now there is only 1 down there.
    ivanhoe likes this.
  10. ivanhoe
    ivanhoe
    Northern Ontario
    I remember you mentioning only 7 but I wanted to make sure. The less the better because of the limited cfm's of the distribution fan. Mine doesn't have a punch of air either but by being more continuous makes up for it!
    BAN83 likes this.
  11. Old Fart from Eganville
    Eganville, Ontario
    My furnace guy was in to check but didn't have his gauge with to check the pressure. But he did tell me that the 10 inch flex pipe
    I am using will only produce 300 cfm and a 10 inch smooth wall pipe will only produce 325 cfm. He checked his chart and I would have to go with a 14 inch round pipe to get close to the 800 cfm the blower produces. I will try it this way for now and just add a couple more takeoffs for the basement to get more heat down. He tells me that my furnace seems to produce a lot more heat than
    his St. Croix does. Guess we have to wait for colder temps to really try this puppy out. So far though I am happy with it.
    Old Fart :fart:
    :thumbs::thumbs::thumbs:
    ivanhoe, imacman and BAN83 like this.
  12. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Not sure that sounds correct, if your not getting the blast of air now .....a bigger vent will make it worse. You need the right size which is 10" but smooth walled will flow better with less restriction.
    imacman and ivanhoe like this.
  13. Old Fart from Eganville
    Eganville, Ontario
    I don't know much about it at all. He looked it up on his formula chart and that is what the numbers were.
    10 inch flex was 300 cfm. 10 inch smooth wall 325 cfm. 14 inch was something like 750 cfm.
    I will just keep playing with. Keep the thoughts and advise coming. I feel a cool one coming on.
    Old Fart:fart::fart::cheers::cheers:
    ivanhoe likes this.
  14. DexterDay
    Northeast Oh
    What I'm wondering, is how is any air coming of of the registers? Or why air would come out?
    I would expect no air to come out of them if the furnace wasn't ducted into the main plenum.
    If your just blowing air out of the stove? Then no air will come out of the vents upstairs (some may.. But you wouldn't be able to feel it. They would act more like a natural return for the basement if the LP furnace is disconnected.
    As for 10" only flowing 300 CFM? That can't be right..?
    ivanhoe and Triple A Arsenal like this.
  15. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    I thought the same , but I think he is saying he disconnected at the main furnace. Then installed the 50f from that point so it uses the existing duct work. He has the term "free standing" wrong...well technically....because he didn't run a seperate set of ducts throughout the house. He is still using existing although the main furnace isn't hooked up. At least that's what I got so far, I might be wrong. As far as I know with all the research I did before doing my install, the duct is sized off the furnace BTU output, not the CFM. I knew and understood before firing up , the 800cfm blower would NOT be like my 2000cfm blower for the oil eater. Which shot so much hot air so fast it gave my wife bloody noses from the amount of heat rushed up. But also cooled down the house so quick. Now I have less blowing up, but HEAT SOAK baby! Even the floors are warm.
    I'll never go back, unless of course it's an emergency.
    ivanhoe likes this.
  16. DexterDay
    Northeast Oh
    Just went back through this thread..
    There is so many 50F users, it's hard to keep track of. I see YOU ARE connected to your Existing HVAC.
    Is the old LP furnace sealed off? So no air can leak back out of the system?
    And as stated before, the fewer the vents? The better they will flow. I have 7 vents and will be adding an 8th this winter to my living room. But it's all insulated and I have no Cold air return. This may hurt my efficiency, it may help it. But my furnace has no problem heating 2,000 sq ft upstairs and over 900 of the downstairs /no cold air return. So warm are goes through the basement cat door.
    ivanhoe likes this.
  17. Old Fart from Eganville
    Eganville, Ontario
    :cheers::fart:
    Totally separate from the LP furnace. Pellet furnace is standalone hooked to its own duct and return air. I am going to try to attach a chart I found online for duct sizing and air flow. If it doesn't work you can check it out yourself , just type in home duck work sizing and air flow chart you should be able to find it. Have a good Xmas and tell the young lad of yours congrats on that first buck. It is a beauty.
    Old Fart:fart::cheers::cheers::cheers:
  18. Old Fart from Eganville
    Eganville, Ontario
    Kinda screwed that other reply up. Hear is the chart. Sorry Dex I cant make it happen
    ivanhoe likes this.
  19. imacman
    imacman
    Denver, NC
    Nope, not yet......:whistle:
    ivanhoe likes this.
  20. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Oh ok, in that pic it looks like a plenum.
    ivanhoe likes this.
