New Chainsaw, Stihl 362 Carbureted or 362 M-Tronic
Discussion in 'Chainsaws and Power Equipment' started by CamperLifestyle, Nov 19, 2017.
  1. blacksmith
    blacksmith
    central Pa
    I know I've been frustrated with the 661 with the M-tronics. Had it a little over a year and been to the dealer at least 6 times! Hopefully this time it's fixed because they put all new updated M-tronics on it!
    Rope likes this.
  2. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    That's a great deal. I've had my 362CM for a couple years now and its been perfect. Starts everytime, no matter the weather.
    Rope, Fabz and blacksmith like this.
  3. Fabz
    Fabz Banned
    Buffalo ny
    Either saw will perform well for you ... having owned both carb and mtronic I would recommend the mtronic ... also if you find you need / want more performance I have a mod for that saw that really wakes it up ! With the carb version you will have to tune it ; with mtronic it will automatically compensate
    Rope and blacksmith like this.
  4. Fabz
    Fabz Banned
    Buffalo ny
    Here’s the 362cm with the mod and a Razer-chain in red oak ... bar is 18”
    Mitch Newton, Rope and blacksmith like this.
  5. Rope
    Rope
    Alaska
    I just picked up a 441r-cm, it’s a beast. I put a 25 inch es light bar. I paid $1,178 that includes a six pack of synthetic stihl oil for the 2 year warranty. There is a lot of debate on what is better. As stated by those that have them, most like them. One thing I have repeatedly heard is don’t let them idle. Some that have issues had a bunch of idle time and they have issues. I have been running mine like I stole it. If your cutting big lodgepole pines you may want a little bigger saw. I have heard claims that the 441 is the most r&d stihl has put in a saw. I have some of the older 036’s and a 034 super and I really like that series. No matter what one you get you will be served well.
    blacksmith and concretegrazer like this.
  6. Fabz
    Fabz Banned
    Buffalo ny
    I
    I have the same saw Rope ... with muffler mod and razer-chain the 441cm is a ripper ... not too shabby on the gas mileage either !
    blacksmith and Rope like this.
  7. Rope
    Rope
    Alaska
    I was just in the classifieds and saw your post on mufflers. Watched the videos. You have me thinking....
  8. CamperLifestyle
    CamperLifestyle
    North Idaho
    Thanks for all your input. Now a question my wife has, since she is reading. Will the M-Tronic start easier?
    Rope likes this.
  9. Rope
    Rope
    Alaska
    Yes, I was just cutting in-18* and it started in 2-3 pulls. First pull was in the off position, second in choke sputtered for a few, I didn’t get to the trigger quickly. Next pull in run position fired and stayed running. When the saw is warm from inside it cranks 1-2 pulls. All my other saws take 3-5 more pulls to get them going. They always fire, at -30* or colder I keep my saw by the fire before i crank.
    blacksmith and CamperLifestyle like this.
  10. CamperLifestyle
    CamperLifestyle
    North Idaho
    She would like that, since she doesn't like the pull start. But heck that ain't going to stop her, just slow her down at the start.
  11. Kimberly
    Kimberly
    The Kangaroo State
    Here is my take, if you are going to be going up and down mountains to cut wood, then get the tronic stuff as it supposedly will make changes. Otherwise, stay with the non tronic so you won't be cussing it and throwing it under the bulldozer on purpose.
  12. lukem
    Probably not easier, but the starting process is simpler with the M-tronic.
    Reg Carb (cold start):
    1.) Set full choke
    2.) Pull rope until it "pops"
    3.) Set to half choke
    4.) Pull rope until it starts
    5.) Blip throttle to get to idle
    Reg Carb (warm start):
    Could be no-choke, half-choke, or full-choke. Depends on a lot of variables.
    M-Tronic (hot or cold):
    1.) Push lever all the way down
    2.) Pull rope until it starts
    I have a 362 CM and it has been 100% reliable for 3 or 4 years now. A great firewood saw.
  13. MasterMech
    If the non-M 362 has the old, original to the 362, air filter, that alone would steer me to the CM version. Did the 362 get the same kind of massaging (lighter weight, slight power bump) that the 261 did? That too would steer me away from the older design. M-tronic has been VERY reliable with only the MS661 having consistent issues (with well documented fixes already available).
    The only time I'd want a conventional adjustable carb over the Mtronic would be if I was using the saw exclusively to prune or limb trees or otherwise cutting in such a fashion that the system would not really get the opportunity to self-adjust. Or a saw dedicated to racing/get together fun.
    Moparmyway, Fabz and Rope like this.
  14. lukem
    That's a really good point. The air filter on the 362CM is unbelievably low maintenance compared the older saws. I will tap out a few fine particles every 5-6 tanks or more, where the old style will get completely caked about every tank or 2.
  15. Fabz
    Fabz Banned
    Buffalo ny
    Yeah I hear ya Rope ... cheap mod ... remove muffler -if u have access to a grinding wheel .100 wide u can grind into the bottom “groove” and remove it ... then remove all burrs with file and emery ... wash in hot soapy water and make sure u get all the shavings out of the muffler .... reinstall muffler and enjoy a free boost of power ... u can do the job in an hour or so ... this way your saw ain’t down k .... I can send ya a chain or two if u need faster cutting
    Rope likes this.
  16. Fabz
    Fabz Banned
    Buffalo ny
  17. Fabz
    Fabz Banned
    Buffalo ny
    Hope that helps ya out Rope ... makes for a nice - gain on the cheep and your saw won’t be down ... it does make it a bit louder but gives it a deeper “throatier” tone
    Rope likes this.
  18. Rope
    Rope
    Alaska
    Cant watch videos at work. Will have to check it out at home. Used the 261c to cut some wood on the way to work, man she runs good, even at -27*. Only 2 tanks through this one so far.
  19. Fabz
    Fabz Banned
    Buffalo ny
    Yessir ... I have the 261c with a muffler mod; modded combustion chamber and the squish at .020 ... I run a 16” bar with 3/8 lp picco sqr/sqr and routinely outcut my associates’ 362c in the same wood ...
    Rope likes this.
  20. CamperLifestyle
    CamperLifestyle
    North Idaho
    Thank you to everybody's Input on this decision. I picked up our new saw today. :)
    We went with the CM 362 Carbureted.
    MS 362 Chainsaw in Ponderay, ID 83852
    It does have the new HD Air filter and "cyclone Filter", got it with a 25" Bar.
    Looking forward to put it to work.
    Thanks again to everyone and have a great weekend.
