Need stove recommendations
Discussion in 'Modern EPA Stoves and Fireplaces' started by kentuckyguy, Aug 12, 2026 at 8:14 PM.
  1. kentuckyguy
    kentuckyguy
    Eastern Kentucky
    I have a new home built last year. I installed a 6” class A chimney during the build.
    I found a deal on a barely used Alderlea T5 and installed it in the basement. This stove ended up not being what I wanted but I’m now trying to decide on a replacement.
    I had a lot of issues with the T5 running off on flue temps even after installing a damper in chimney. My flu is about 28’ straight up from the basement.
    I also felt that even when the stove was running too high of flu temps it didn’t keep the basement warm. I realize heating the basement is gonna be tough because it’s 2100 sq ft of open space and concrete walls.
    Would I be better off to just get an older stove that less efficient?
    I don’t use wood as my primary heat. Just to knock the chill off in the basement or when it’s really cold outside. I mainly use my propane furnace which at my highest month last year was $133.
    Just can’t decide on buying another larger epa stove or trying to find and old fisher and fixing it up. Also open to other options thanks in advance.
    brenndatomu likes this.
