NEED FEEDBACK ON WOOD SPLITTERS!
Discussion in 'Chainsaws and Power Equipment' started by Country Boy Chronicles, Feb 17, 2021.
  1. MikeyB
    MikeyB
    Long Island NY
    Well done. Never heard of a dual fuel splitter.
    Very cool.
    amateur cutter and T.Jeff Veal like this.
  2. Canadian border VT
    What a great side income for a person with many years of experience :tip:
  3. Holland Dell
    Holland Dell
    SW Wisconsin
    X2. However, in my experience RuggedMade has three major faults. 1. The hitch is on the wrong end for a pass-through splitter. 2. Axles are weak and welded to the hydro tank. They bend easily and RM will not honor their warranty on the axles. A solid axle, not attached to the tank, would be a better option. 3. The axle/tank assembly is not set to a balance point between engine weight and beam weight. Other than that (after a few modifications) it's a pretty decent design.
    Horkn, amateur cutter and T.Jeff Veal like this.
  4. TurboDiesel
    Amateur "Buster" Cutter.:whistle:
  5. amateur cutter
    I ain't afraid to use em Tim, you know that.:D
    Chvymn99, T.Jeff Veal and Horkn like this.
  6. amateur cutter
    So when would you like to start building mine?
  7. amateur cutter
    Spot on! I will add that for my purposes the 4 way wedge makes the splits to small as well.
  8. T.Jeff Veal
    Me too.
    Chvymn99, amateur cutter and Horkn like this.
  9. bushpilot
    bushpilot
    Eastern Washington
    I wish my generator had one. Oh, wait...
  10. Horkn
    Lol.
    Jump pack then, plug the Genny into that, and but the button.
    amateur cutter likes this.
  11. fuelrod
    fuelrod
    Western Maine
    I had to look up "axis type" also, turns out that's what I built over 30 years ago :salute:
    Now it was sort of by accident in that I wanted it to be vertical/horizontal. In the horizontal position (that it's used in 99.99% of the time) for countless hours in the past 30+ years I've come to realize how much work and movement it saves not to chase and pull your wood back for subsequent splits with the log stationary and the wedge traveling through your log. Quartering means 2 strokes and a 1/4 turn of the log. I'm strangely fussy about the size of splits and not in a rush, so I'm pretty sure I wouldn't be happy with a 4 way wedge.
    To the OP, depending on the scale you're shop is looking for (number of units built and sold)
    I'd test the waters with a very solid base unit (with the operator standing upright) with a Honda motor and good components that was designed with a log lift and tables that could be fitted to this "base" unit. Adding one or both of these would be a good sales point if the customer could easily retrofit himself, but that's more of a marketing decision as they reserve these as part of a model "line".
    Seems like the economy splitter market is full and wouldn't be profitable for a sideline and there's quite a few customers who'll shell out $2500 and up for a quality machine. One step at a time and develop your line be listening to your customers.
  12. JackHammer
    JackHammer
    I just picked up my first splitter last black Friday.
    I think there is a hole in the manufacturing market. There are a lot of little electric 5-10 ton splitters and then there is the 25 from Tractor Supply that is the low end of the market for gas powered. From what I have seen, there is a range from 10 to 25 tons that is being largely overlooked by the retail market. I bought the 25 ton but what I really wanted was a gas powered 15/20 ton for about $600/700 bucks. I will use it for maybe 2-5 cords a year. I have seen a few reviews of the 25 ton that i have and these people are splitting live oak and say things like, "I don't know why I would need more power"... 25 tons is likely too much power for the job that I need done. I think champion had a mid-range that i was strongly considering. Black Friday sale at 900 bucks was good enough so I locked it in. Champion was about 7 or 8 for about half the power. If it was closer to 550/6, I would have picked that.
    As a good value add, there is a removable shelf / log holder. They are typically sold separately but I think people really like them. That might be a feature you should include if it makes sense financially.
    Ps, I am a data analyst and look at retail market share profiles all the time. Happy to offer un-scientific, biased, personal use anecdotes any time. :)
    amateur cutter, Horkn and T.Jeff Veal like this.
  13. triptester
    triptester
    S.E.Wisc.
    All the under $1000 splitters are made in China. The only component that differs between a 10 and 25 ton gas powered splitter is the size of the hydraulic cylinder. So for a $10 increase in cost they can get an extra $100 in sale price. Typically the tonnage ratings are inflated by up to 5 tons.
  14. RCBS
    RCBS
    Over here
    If you really want to stand out...put a two-way detent on it. Auto split and auto return. Requires two handles. I operated a $15,000 Rayco brand splitter that had it and it is an absolute game changer.
    Working height is important...waist level or higher.
    Under 18 second cycle time.
    Tires capable of highway speeds.
    Light enough to move around without being attached to a trailer hitch.
    Work table is critical.
    Log lift option.
    Position engine or use sheilding to keep debris off it.
  15. Stlshrk
    Stlshrk
    Central Virginia
    triptester Probably true. :thumbs: Time, access, and wholesale/scrap/surplus pricing can save a lot of $$!
    I am envious and hope to be able to retire one day. Hopefully while I still have the sense and will to tinker, fabricate, and such. :tip:
    I fear that my generation will end up working until noon on the day of our own funeral... :heidi:
    T.Jeff Veal, amateur cutter and Horkn like this.
  16. fuelrod
    fuelrod
    Western Maine
    Get yourself a welder now and don't look back.
    It's magic but it's not. Addictive is what it is.
    As long as you're not making a trailer or something that could hurt someone if one of your learning welds fails, it's a very handy ability to have and I find it lots of fun.
  17. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    I have to 2nd this. From brazing something together with coat hangers and an oxygen acetylene torch to mig welding a splitter hinge back on, its so convenient to have and to use a welder as a ready there tool.
    I’ve scraped up a Tig and all the stuff needed to start trying it just haven’t been able to get time. Already have mig and a plasma cutter. Sold my old arc tombstone after getting the mig.
    Go get an inverter welder and have some fun.
  18. fuelrod
    fuelrod
    Western Maine
    I believe (sadly) that's a good way to get sued right into the poor house in today's society.
    Look at the mandated stupidly in a simple lawnmower. Weather it was the government or the manufacturers legal dept. ruling, It's still a big consideration.
    I've been thinking of swapping out my old simple no detent valve and looking at surplus centerscatalog Hydraulics | www.surpluscenter.com
    You'll see the warnings and that's on a loose component, not something you just add gas and go to work with.
  19. JackHammer
    JackHammer
    Might be true, but that doesn't mean there isn't a hole in the pro-sumer category. If I were looking to launch a new product, I would find a customer and hole in the market.
  20. Country Boy Chronicles
    Heltonville, IN
    Awesome replies by everyone! Thanks for the feedback. I'm going through the comments daily and looking at what everyone is saying, hopefully will have a plan put together soon! I will keep you all updated!
