NC30.... Craigslist Score
Discussion in 'Modern EPA Stoves and Fireplaces' started by Chvymn99, Oct 5, 2013.
  1. Chvymn99
    Yep, and its nice to be back at 75 to 80 degrees with her just running around the 450 degrees
  2. Chvymn99
    She is a totally different animal than the 13. I could usually predict the 13, but this 30 has got me relearning my habits. But the secondary's are phenomenonal on the 30!:D
    raybonz likes this.
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    Secondaries on the 30 are amazing!!
    Congrats!!
  4. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    How are you loading and when are you adjusting the air?
    Chimney height? Lined? Top temps you are hitting?
    Chvymn99 likes this.
  5. concretegrazer
    concretegrazer
    Southwest MO
    Now you're talking my kind of house temps!:thumbs:
  6. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Nice avatar. Didn't anyone ever tell you that it is impossible to get a Hearthstone over 500 degrees? :D
    DexterDay and concretegrazer like this.
  7. concretegrazer
    concretegrazer
    Southwest MO
    When they made my Mansfield they must've had some progress.:cool:
    Your heritage thread should be printed in the hearthstone manual.:thumbs:
    DexterDay and BrowningBAR like this.
  8. Chvymn99
    Right now I've been loading NS predominately. Honestly couldnt tell you details on when adjusting. Just been trying to see how it reacts. Just generals. Been waiting for the stove pipe hits 275-325 and/or when notice the stoves getting 350 to 400. I finally hit a little over 600 yesterday and you could smell the paint curing. It seems to settle nicely where the brass knob is almost under the lip of the catch tray. I've been trying to stay around 300 to 400 degrees, unless it get back down to zero then I had to take it up a bit. But the 13 I had to run pretty hard & stay on it. This seems to allow me to let it cruise at a much lower temperature.
    The chimney is 21 ft( I think I'll verify later). Triple wall after 7 foot. My big catch is the double 90 that's at the 7 foot mark. I've got to figure how to get that out. It didn't really bother the 13 but the 30 I see some resistance.
  9. Chvymn99
    How do you adjust? Any tips?
  10. Chvymn99
    Well, it kinda roll off this afternoon, since it was 80 something in the house. Plus I had a Birthday party to go to. Got back about 7 ish and reloaded with my fullest load yet, about 8 decent chunks of Oak. The back two E/W and the front line N/S. At 7:30 I got combustion. The inside temperature started at 72, now at 8:22 we are at 76. I let it set pace on the stove pipe to around 300, stove top was upper 200 low 300. I started shutting her down, got a nice flame going. Its been sitting at 450-500 for the last 20 minutes or so, with a beautiful flow of secondaries going on. The push in tube is definitely below the catch lip, but not all the way down. I'm really curious on the length of time this burn will last.
    Just off note. Its been over 3 days at these out door temps and I still haven't dumped ash's or coals out. At these temps it was a daily or every day and half chore to do with the NC13.
    The only one issue that I want to fix, should have done it with the last ones. Is the double 90 (over very close to), need the angle to get to clear rafters, but would like to get it started earlier to lessen the angle.
  11. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I pay more attention to how the fire looks than the stove top temp. Once the fire catches firmly, I adjust some more. Usually end with the air control just inside the ash lip. Don't be afraid of 700. When doing a full e/w load, make it tight. If your splits are shorter than the firebox, load the box tight to the right and load n/s in the remaining space to the left.
    DexterDay likes this.
  12. Chvymn99
    Ok, I'll have to try that. Pretty much my load for the next year will be shorter, cut for the 13. But I've been cutting for anticipation of the last three years for the NC30.
  13. DexterDay
    Northeast Oh
    Yep. Just under ash lip for a good burn, or just outside the lip for a hot/faster burn.
    The 30 reacts very well to small adjustments in air.
  14. Chvymn99
    Its 8 degrees outside/windchill of -3 right now. I got up at 2 and opened up the air supply. When I got up at 4 it was still 75 degrees in the living room and the stove top was still running around 200 to 225. Which I'm thrilled with, thats roughly 9-10 of solid heat. Plus no ash's to take care of yet.
    raybonz and fox9988 like this.
  15. DaveGunter
    DaveGunter
    I'd be interested in hearing what you experienced nc30 burners have for a temp differential between the stove top and the pipe when the stove is cranking.
  16. Chvymn99
    Haven't had it cranking, so far I've kept it pretty much 400 to 500. I did peak at 600 a bit on Saturday. But my pipe temperature is stays up around 200 to 325, then it goes down as the stove temps drop.
  17. DaveGunter
    DaveGunter
    Thanks, how is that pipe temp measured, single or double wall?
  18. Chvymn99
    Single wall
  19. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I'd love to tell you, but my IR gun seems to be hiding.
  20. Chvymn99
    Well, this is going to be our coldest night that we've hit this year. Its been a cold day in itself. Its suppose to drop to -4 tonight. Got the NC30 Stocked and Rockin'. I'm LUVin' this stove. Loaded up this morning at 5:15 and by 5:30 the house was sitting at 71, the stove top was about 230 (high of 12 outside today). Doing everything I wanted it to do. Now tonight I just loaded at 8:15 with Mulberry/H. Locust & Hedge. Heres the load:
    Its about 1 1/2 hrs later and the stove it rockin' at 575, room is sitting at 75. Cant wait to see it response to this load.
    DexterDay, BrowningBAR and raybonz like this.
