Napoleon NPS45 - Control Board issue
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Geek, Oct 26, 2016.
  1. imacman
    imacman
    Denver, NC
    Real cheap dollar store hand sanitizer is mostly alcohol, so take a cup of pellets, soak in gel, throw in burn pot........
    gbreda, Geek and jtakeman like this.
  2. jtakeman
    You forgot the poof! :D
    I forgot about the sanitizer, Its the closest thing to the gel stuff and works dandy. Seeing its cold season. Many stores will have it on hand too.....
    gbreda and imacman like this.
  3. Geek
    Geek
    I pushed the pins in the connector, but no igniter, so used hand sanitize to start it up.
    Let's see if it keeps running overnight.....
    imacman and jtakeman like this.
  4. jtakeman
    Hi/lo mode?
  5. Geek
    Geek
    BTW - I am wondering about other cables....the wires were a bit stretched since the side panel was hanging down a bit.....guess will recheck tomorrow but would like to know which exact wire is the one for the igniter coming into the connector, if someone knows...
  6. Geek
    Geek
    running in low, #1.
    But just removed the film from the outside and was able to push heat button for #2 heat.....hmmmm maybe the film was the issue with the buttons to begin with....
    I still have side panel open and hanging on a side.....
  7. jtakeman
    The film is on mine. Stiff as heck. I could not get mine to turn in until I pushed so hard it broke through the film. Once my finger hit the button it fired up.
    I'm likely to order a new one. Gonna price a new one soon. Likely after the holidays. As long as it aint nuts on $$?
    imacman and gbreda like this.
  8. Geek
    Geek
    Anyone knows the specific wire for the igniter coming into the plug?
    jtakeman likes this.
  9. jtakeman
    The manual wiring diagram says its the orange wire.
    Geek and gbreda like this.
  10. Geek
    Geek
    Ok, will check it out but I know I pushed all wires into the plug really well.
    The wires coming out of the igniter (I think I saw 2) were white if I remember and do not go directly to the board but actually plug into a connector near the auger....that is what I remember.....:rolleyes:
  11. imacman
    imacman
    Denver, NC
    That's the connectors you'd unplug if you want to try direct 120v to see if ignitor is good.
    gbreda, jtakeman and Geek like this.
