My summers heat 2400 thread
Discussion in 'Modern EPA Stoves and Fireplaces' started by Warner, Feb 16, 2020.
  1. Warner
    Warner
    A4C2D187-BE3D-4D45-A079-98FD78D063B8.jpeg The boy made a house out of the stove box. Here he is installing the chimney.
    Maina, papadave, Thor and 5 others like this.
  2. brenndatomu
    Awesome! Boxes still make the best toys! :thumbs:
    I saved the box from our new water heater for the kids to use as a tunnel out in the garage while it was too cold to go outside to play...
    Chazsbetterhalf likes this.
  3. brenndatomu
    Quite annoying that such a minor detail went unchanged, even after they were made aware of it, huh?! Should have never made it past their design dept...or QC!
    Good solve.
    Chazsbetterhalf and Hoytman like this.
  4. billb3
    Couldn't the minimal door/knob clearance (with a little stretch of imagination, Hey Disney and Microsoft do it) be considered a feature somehow ?
    papadave and Chazsbetterhalf like this.
  5. Kimberly
    Kimberly
    The Kangaroo State
    Try to avoid hitting the baffle when adding wood as they are sort of fragile. The good thing is they are loose so if you do hit them they just get dinged; mine has quite a few dings.
  6. Kimberly
    Kimberly
    The Kangaroo State
    A future member of the FHC.
  7. Hoytman
    Hoytman
    OH
    Will certainly be better and easier on wood and the outside air. Big question remains if it will throw the heat that Warner is a capable of. That isn’t really the issue either. What will be the tell all is if it throws the heat you need while using less wood and making you happy. The last part will seal the deal.
    Priceless photo of your son!!! You will cherish that for years. I love children!!! They are such a blessing to our lives.
  8. billb3
    He's good with a knife.
    Pampers for a clean chimney was a good choice.
  9. Warner
    Warner
    I used the knife under his direction.
    my uncle did give him a Swiss Army knife recently. I though my wife was going to have a heart attack!
    Maina, Kimberly, brenndatomu and 2 others like this.
  10. Eric VW
    Great pics, nice install Warner :yes:
    :fire:
    :thumbs:
  11. Warner
    Warner
    Thank you, I still need to fasten the pipe together I forgot to get screws when I was getting the piping.
  12. Warner
    Warner
    Time will tell... I’ll try to keep you posted.
    I do not expect this stove to be able to put the heat out the wood beast did. I know it won’t. Fill that thing with a healthy arm load of 26 inch splits open the draft and look out!
    repeat every 4 hours.
  13. Hoytman
    Hoytman
    OH
    Lol!!! Yeah...all those stoves like that we’re capable of nuclear meltdown temps.
    You should have all the heat you need, I hope and think so, while using less wood to boot. Always a plus.
  14. Warner
    Warner
    One thing that is defiantly going to have to change is my fire tools. They all work on a stove that is almost 2 1/2 feet deep. Way to long for the new stove.
  15. Warner
    Warner
    If not it will go on Craigslist. The beast will be happy to go back into service.
  16. Hoytman
    Hoytman
    OH
    Pete Rose said ‘if choking up was good enough for Tye Cobb, then it was good enough for him.’ Hard to argue with the two greatest hitters in the game. Not sure if it applies to wood stove tools, but it’s with a try. Lol!!!
  17. Hoytman
    Hoytman
    OH
    I hear you. My old wood stove is on deck for some repairs. Plans are being made for modern modifications and a possible reliever position just in case her services are ever needed again.
  18. brenndatomu
    Sounds like you have the right perspective...even though the new stuff is more efficient, it also takes more time to complete all the phases of a burn...especially coaling, and since BTU/hr output is largely about how many lbs of wood you can incinerate per hour, taking twice as long to burn that "healthy arm load" means less BTU output in that hour.
    Its all about finding the right balance between efficiency and "horsepower"...
  19. brenndatomu
    "Too long" is better than "too short" :whistle:
  20. Hoytman
    Hoytman
    OH
    Important point many may not think about or have knowledge of.
    The question remains though if the stove can literally “take the heat” when and if it’s called for. Not having experience with this stove or any newer modern stove, I can’t say if any of them can “take it” if called for...running wide open often, that is. As you mentioned, the balance point is what he’s after and I’m rooting for that for him.
    Maina and Chazsbetterhalf like this.
