My Stove Arrived!
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Jan 30, 2016.
  1. T-Stew
    T-Stew
    Well you can always upgrade later right? Hopefully you'll be happy with your stove, but don't dismiss that you'll never have the one you want. You never know when you might happen across a deal. I have a nice lookin' green porcelain enameled cast iron stove that is barely used that I'll be getting rid of at some point (it is just taking up space in my living room in the corner). Not a single scratch on it I do believe, except for what was on it when new. Probably sell it for less than half. Still, more than your stove, but just saying good deals to pop up every once in a while.
    HDRock, Horkn, Eric VW and 1 other person like this.
  2. HDRock
    Correction , that 3.2 cu ft Firebox will be more than enough for your 1000 sq ft :fire:
    Is that correct ? 1000 sq ft , is that what you have ?
    Horkn, Well Seasoned and Eric VW like this.
  3. Eric VW
    Little more than that IIRC....
  4. papadave
    Correction to "should be".
    The 30 "should be" way more stove than I need, but isn't in some situations. :headbang: Slightly bigger house, although we normally only heat about 900 sq. ft.
  5. HDRock
    Yep that's for sure , depends on the sitsheation
  6. papadave
    Man, I'm glad you didn't mis-place that H. :D:rofl: :lol:
  7. HDRock
    :rofl: :lol: Just guessed at spellin it :whistle:
  8. Kimberly
    Kimberly
    The Kangaroo State
    I am not sure. There is my little office and another small bedroom but I doubt if the air flow will be able to heat them that well; they are off of a short hall. I have not been heating my bedroom but the door to my bedroom is off of the lounge so the heat flow may help to warm the bedroom. My bathroom is on the other side of my bedroom so I will probably still need the electric radiator in that bathroom.
    Well Seasoned and Horkn like this.
  9. Kimberly
    Kimberly
    The Kangaroo State
    What is IIRC?
    Well Seasoned, Horkn and Eric VW like this.
  10. HDRock
    My house is chopped up , I think you will be surprised how well you can heat the other rooms with small fans ,on the floor in the doorways sucking cold air out and blowing it towards the stove room , the electric the fans use is not that much, and well worth it.
    Edit, I have electric heater in the bath room too, for fast heat for my buns when it's chilly in the morn
  11. Eric VW
    "If I recall correctly"
    I spelled it out on another one of your threads....
  12. Kimberly
    Kimberly
    The Kangaroo State
    I will use the search feature of the thread and see :D
  13. HDRock
    You never measured the outside of your house ?
  14. Eric VW
  15. bushpilot
    bushpilot
    Eastern Washington
    A woodstove throws off a lot of radiant heat as well, so it heats somewhat through a wall. More than I thought it would.
  16. JA600L
    JA600L
    Lancaster, Pa
    Let's see some flames.
  17. Deano31
    Deano31
    Good luck with the new stove hope it keeps you and your family warm that's the only thing that is important
    Sean, milleo, mattjm1017 and 2 others like this.
  18. Kimberly
    Kimberly
    The Kangaroo State
    Yes, hope to be burning soon.
    Eric VW, Sean, papadave and 1 other person like this.
  19. yooperdave
    If and when you have trouble with starting/staying lit/burning/glass sooting up....don't blame the stove or the vent. Your next obstacle is the wood. 3 years makes all the difference. 2 years is good, 3 is what you want. You,ll see.
    Stove looks huge! Will the venting still line up with where your thimble is?
    Eric VW, papadave and Well Seasoned like this.
  20. Kimberly
    Kimberly
    The Kangaroo State
    Yes, I planned for a larger stove; at first it was going to be a smaller stove but I knew I had to plan for future.
