My Hearth Pad
Discussion in 'The DIY Room' started by Kimberly, Feb 10, 2016.
  1. Kimberly
    Kimberly
    The Kangaroo State
    I have asked my brother-in-law to come and help me get the stove inside. I moved everything out of the way last night so if we can get it on the hand dolly, it will be wheel and place; I hope.
    Horkn, milleo, papadave and 2 others like this.
  2. milleo
    milleo
    Maine
    And when is brother-in law coming...Waiting for pics....:popcorn:
  3. Kimberly
    Kimberly
    The Kangaroo State
    They have just left, the stove is sitting in the lounge on the hearth. I am in the process of putting it back together. To make it even lighter, I took the heat shields off, those shields are heavy metal, this is no cheaply built stove. I may need to go get more stove pipe. I will need to cut the pipe to length as the lengths at Tractor Supply was limited. How do I cut the stove pipe?
    Horkn, BrianK and Eric VW like this.
  4. Kimberly
    Kimberly
    The Kangaroo State
    Tractor Supply had a pretty Ashley pellet stove on display with a beveled glass door; sign stated it was discounted $300.00.
    Horkn, wildwest and Eric VW like this.
  5. milleo
    milleo
    Maine
    Good luck with that, I planned mine out so I didn,t have to cut anything....
    Horkn, Eric VW and HDRock like this.
  6. HDRock
    Great job , looks real nice :thumbs:
    Are you getting excited for a fire yet ?;):D
    Horkn, Eric VW and milleo like this.
  7. Kimberly
    Kimberly
    The Kangaroo State
    That was being smart; my problem was I was unsure of the stove and the hearth etc. I probably did everything backarsewards as Dad use to say. I am heading back to Tractor Supply, they had some 12 inch lengths that may work better.
  8. HDRock
    if you are getting snap-lock pipe you can cut it before you lock it together with aviation cutters or tin snips, after it is locked together you can use a dremel tool or die grinder
    Horkn and Eric VW like this.
  9. Eric VW
    Good idea on cutting it before snapped in, HD:thumbs:
    I snap it together and use the angle grinder w/ a thin cut wheel to cut to final length.
    Horkn and HDRock like this.
  10. BrianK
    BrianK
    West central PA
    Dittos. Except I clamp the angle grinder in the vice and hold the black stove pope with gloves and cut it on the thin cut wheel. Very carefully.
  11. Eric VW
    Another great idea!:thumbs:
    Horkn likes this.
  12. HDRock
    Angle grinder would work well too:)
    I prefer to cut it after it is locked with the die grinder, gives a nicer cut than snips
  13. papadave
    Just get a piece of slip pipe. Done
    milleo, Horkn and Eric VW like this.
  14. HDRock
    Yep, I got my SW slip pipe at Menards
    Horkn, Eric VW and papadave like this.
  15. papadave
    Makes it WAAAY easier. My time and psychological stability and worth the few bucks to use that stuff.
    milleo and Eric VW like this.
  16. Eric VW
    What is this "slip pipe" you mention?
    Horkn likes this.
  17. papadave
    One piece inside another. Got mine at a local stove shop, made by Heat-Fab.
    Kinda like a Trombone slide.
  18. HDRock
    The single wall slip pipe I got was inexpensive, it's 24"
    diameter is just slightly larger than a regular 6 inch pipe
    papadave and Eric VW like this.
  19. Kimberly
    Kimberly
    The Kangaroo State
    Yes, that was all Tractor Supply and Lowe's carried. Is it OK to use?
    Horkn likes this.
  20. Eric VW
    Just looked it up... How does it "seal" up?
    This could make taking the flue pipe off for cleaning, easier?
    papadave and Horkn like this.
