My first IBC tote
Discussion in 'The Wood Pile' started by grandgourmand, Feb 23, 2022.
  1. WeldrDave
    Sweet! Nice haul!
  2. LordOfTheFlies
    LordOfTheFlies
    NY
    Hm........interesting. I stand corrected!
  3. WeldrDave
    For what ever reason, they are like trying to find Gold nuggets in a Cracker Jack box around here! o_O Nobody seems to have them and when you do see them, they're being used.
  4. WinonaRail
    WinonaRail
    Indiana, US
    I was referring to the previous contents. Having been filled with motor oil, they just aren't that pleasant to deal with. I've had others there were used to transport ionized water or algaecide. Once rinsed, they look like new.
  5. sirbuildalot
    sirbuildalot
    Mass
    The worst part of mine was cleaning out the black mulch dye residue. Spent a full day with a Tyvek suit, goggles, a pressure washer and a stiff bristle brush.
  6. LordOfTheFlies
    LordOfTheFlies
    NY
    Yuck!
  7. Slocum
    Slocum
    North Central Indiana
    All the bladders I don’t use I recycle, cut them so they lay flat and you can haul several.
  8. Slocum
    Slocum
    I’ve hauled 16 on a 18’ trailer 2 different times. Last time I was coming out of Michigan in some lake affect snow with a lot of wind for about 50 miles. They caught a lot of wind and there’s no weight there. I didn’t wipe out but it was close. The things we do for firewood.
  9. Slocum
    Slocum
    I got 4 free totes from a local farmer. The all had different chemicals in them. They were the nastiest bladders I’ve ever dealt with. I cut the bladders up and recycled but I won’t mess with them again.
  10. T.Jeff Veal
    Might be worth a try...might not need 3" holes, maybe a few 1 1/2-2" holes...:handshake:
  11. LinkedXJ
    LinkedXJ
    Indiana
    I have dibs on probably 15 of them totes.
    Not even sure if i want them or what i would do with them.
  12. amateur cutter
    Well, at least we had a decent lunch lol. Or did you get another batch somewhere up here?
    T.Jeff Veal and brenndatomu like this.
  13. Slocum
    Slocum
    Nope, that was your batch. Still in debt to you.
  14. amateur cutter
    No sir, I don't keep score with friends or family.
  15. Casper
    Casper
  16. T.Jeff Veal
    I wish I was closer to you then, if you didn't want them...
  17. WeldrDave
  18. LinkedXJ
    LinkedXJ
    Indiana
    If i had a tractor with forks, sure id use em.
    No tractor with forks.
    T.Jeff Veal likes this.
  19. Barcroftb
    Barcroftb
    The Mitten
    WeldrDave hows the plastic pallet supply in your area? Little more than a cattle panel, a plastic pallet, and some rubber roofing will yield similar storage as an ibc tote cage. I can get cattle panels here for around $25 and 40” x 48” plastic pallets used for $10-20.
  20. brenndatomu
    Man, the last one I bought a couple years back was $16...never mind me, still having trouble getting used to the current inflation rate! :mad:
    T.Jeff Veal, Softwood and Barcroftb like this.
