My first IBC tote
Discussion in 'The Wood Pile' started by grandgourmand, Feb 23, 2022.
  1. Chazsbetterhalf
    Chazsbetterhalf
    Drill little hole in the roof and zip tie to the cage.
  2. brenndatomu
    Could make 2 slits in the liner and use hose clamps for "hinges"...more durable than zip ties, especially white zip ties (no UV stability...use black ones outdoors)
  3. WeldrDave
    I can't even find them around here unless I travel to near Phila, 1-1/2 hours. o_O
  4. WinonaRail
    WinonaRail
    Indiana, US
    I have generally paid $20-$25 each around here. I found a local (rural) school that buys oil and DEF for their bus garage. Bladders aren't good but the totes are free. I take all they will give me.
  5. brenndatomu
    What's wrong with the bladders?
  6. sirbuildalot
    sirbuildalot
    Mass
    The ones around me in MA were pricy. I ended up going about an hour away deep into CT to get 20 of the 330 gallon totes for $20/piece. It’s worth making a trip for larger quantities. Make a small day trip out of it to Philly and get lunch with your lady :)
  7. WeldrDave
    I'd like to do that but everything on Craigslist are about $100.00 a piece! o_O The last 2 I bought were $75.00 each.
  8. LordOfTheFlies
    LordOfTheFlies
    NY
    TWENTY? I can fit TWO on my truck. Holy moly how did you transport 20 of them??????????
  9. Barcroftb
    Barcroftb
    The Mitten
    Sucks you don’t live closer to a rural/farming area. Folks if your trying to buy these off Craigslist and the like you are paying a middleman for them. Oftentimes around here they are free for the taking at large farms. They come with vast quantities of round up or similar herbicide/pesticides in them. Not food safe but plenty gooder for farwood.
  10. T.Jeff Veal
    We did our totes a bit different. Started making a door, use conduit couplings for the hinges and top catch. 0207221752a.jpg
    Some we left the bladders in, used 3" hole saw for air flow holes 0207221903.jpg
    Also made doors on these for chunk/shorts storage. 0207221905.jpg
    The first shorts/chunk bin we did. Have since put the 3" holes in it as well 0127221046.jpg
    We used the bladders for roofs as well, black zip ties thru 3/8" holes drilled in edges... 0115221312.jpg
    I'm thinking of an idea of taking the bladders out, cut tops off, fasten the bladders to plastic pallets, and having double storage.
  11. WeldrDave
    Great Ideas!!!
  12. Barcroftb
    Barcroftb
    The Mitten
    WeldrDave it might be worth asking at a landscape supply yard. Mulch dye is often delivered in ibc totes. It’ll be the season for that here pretty soon.
  13. buzz-saw
    buzz-saw
    Ct.
    Very good idea on the folding door done with the couplings.
    I might have one or two coming , I don't think they have bladders but not sure. going to keep this idea in mind.
  14. sirbuildalot
    sirbuildalot
    Mass
    We actually got 24. I bought 20-330's, and I bought 4-275's for my brother for helping me. He has a smaller tractor and wanted the smaller totes.
    We went with a 1 ton dump that has a 9' x 6.5' or so bed, and a 20' x 8' or so tag along trailer. I also took my little Frontier with 5' x 10' trailer.
  15. sirbuildalot
    sirbuildalot
    Mass
    The place I bought them offered a discount if you bought at least 20. It was worth it to me to figure a way to get 20+
    1 tote was $50 each
    5 or more was $35 each
    20 or more was $20 each
  16. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I like the little dump truck. I got it in my head that I need one similar. I could probably round up 100 totes and make a trade
  17. LordOfTheFlies
    LordOfTheFlies
    NY
    HOOOOOOOOOOOOOOOOOOOOOLY MOOOOOOOOOOOLY that looks like fun!
  18. LordOfTheFlies
    LordOfTheFlies
    NY
    Those 3" holes are nice. I went with the traditional 4,856 1/2" holes per tote....only because I knew I was gonna store kindling in there and I didn't want any of it escaping!
    Btw I believe those bladders need to be supported by the cages. They will burst if filled with anything other than feathers. When I took them out to cut the tops off......they were ok.......but once I cut the top off the whole thing started wobbling all over the place and lost all of its eagle powers (movie reference anyone?).
  19. T.Jeff Veal
    Thanks, just remember to cut the bottom and top horizontal bars about 1" away from vertical bars, so coupling will have something to set on.
  20. T.Jeff Veal
    This guy, Phil Anderson on FB, has been using just the bladders. I might just try a couple. FB_IMG_1645795803539.jpg
