Murphy's Lawndry Room
Discussion in 'The DIY Room' started by basod, Aug 27, 2015.
  1. brenndatomu
    Right, Turbo D said he works commercial...mainly water/sewer plants...that's what I was referring to
    Eric VW likes this.
  2. TurboDiesel
    Yes, pipe fitter. We do plumbing and heating too.
    And wrenches and sockets up to 2"
    I don't do any bidding, but, the short answer is, yes
    eatonpcat and Eric VW like this.
  3. HDRock
    Short answer yes!!! thank you:)
  4. TurboDiesel
    No flow issues at 50-75 psi, pressure is pressure, doesn't matter the shape.
    Drains get sweeps and wyes and 45* bends
  5. badbob
    badbob
    Do not know how you got to this,be willing to bet you never soldered in a air chamber for a faucet.be willing to bet you never heard air hammering in a residential setting,old iron pipes.Water can slowly take in air,but faster under a hammering situation,still a long period of time,which is one reason for central pressure tank.
    TurboDiesel likes this.
  6. badbob
    badbob
    Pressure is pressure?Any restriction,however slight lowers the volumn.In hydraulics,with x number of fittings/angles,you up the overall size of the system to keep the volumn.In a house you do not run 3/8 for 40 feet,you start larger and drop off size closer to taps.Pressure is mostly irellevant if you do not have volumn.Same in a flue for pellet stove,too many bends and you have to go up a size.
  7. TurboDiesel
    We use bladder/diaphragm tanks, because tanks without them get water logged.
    We use piston type shock absorbers on smaller systems rather than air chambers for the same reason. Especially in bathrooms where there are many fixtures with flush valves.
    Eric VW likes this.
  8. TurboDiesel
    Doesn't matter what size pipe you run through your house, without pressure you can't flush your toilet
    sorry for the hijack basod :Yar:
    Canadian border VT and Eric VW like this.
  9. Eric VW
  10. basod
    basod
    Mount Cheaha AL
    No problem.
    I worked for a friends father in college roughing in hot water heating systems in commercial applications. I'd get so far ahead of the "licensed" plumbers sweating joints, that the foreman finally asked if I wanted to start soldering. At first my reply was "when one joint leaks you'll be cursing me out when I'm back at school" he grinned and handed me a torch, showed me a few tips on a couple test fittings and set me loose.
    The only time I've ever had a joint leak is on a repair when you're fightng some residual water steaming off - near impossible to get a joint hot enough
  11. Canadian border VT
    Yup basod I was 12 years old and 70 lbs and smal....l my 6 4 grandfather decided I was going to learn in a closet he couldn't fit into.... a few minutes of showing and said let's do it...
    if you are not experienced buy a good solder and flux! or use PEX!
    basod, TurboDiesel and Eric VW like this.
  12. Eric VW
    Balled up WHITE bread makes a good dissolvable plug....
    Not WHEAT, sourdough, grilled cheese, pannini, naan, tortillas... !!!!!
    basod, Norky and TurboDiesel like this.
  13. Norky
    Norky
    This works every time for me. Just be sure to take all the aerators off the faucets before turning the water back on.
    Eric VW likes this.
  14. brenndatomu
    All of a sudden I need a snack...:)
    Eric VW likes this.
  15. TurboDiesel
    :rofl: :lol: yep. done that. :emb:
    what a mess :picard:
    You ever use a pipe freezer?
    Norky and Eric VW like this.
  16. Norky
    Norky
    Never heard of it. Sounds like it costs money.
    Eric VW likes this.
