Muffler mod for the MS-250?
Discussion in 'Chainsaws and Power Equipment' started by WeldrDave, Dec 10, 2013.
  1. WeldrDave
    Also check with your local saw shop; one that I go to always has saws that don't get pickup and they have sales the start of each year to clear space in the saw shop
    H2H, We have 1 stihl dealer here with in a 35 mile radius, and saws of anykind go fast! "ONCE in a blue moon" there is a flea market around here and you'll be lucky to see one there.
  2. WeldrDave
    Yup, looked at them, I'm gonna get one and hack it up! Thanks for all the input Guy's!!
    MasterMech likes this.
  3. clemsonfor
    That should of said "new or used OE...". Danged auto correct!
  4. H 2 H
    H 2 H
    I have 7 Stihl dealers within 40 miles of me now :)
  5. Hedgerow
    Hedgerow
    SW Missouri
    I've found on these clamshells, the closer to straight in and straight out you can get, the more power they produce... And noise..;)
    Raising the comp on them is not an easy job... I have welded a large pop up on the 039, and only managed to raise the comp by 10 pounds...
    And for that, get added vibration... One would be better off to find a piston of same diameter but higher crown, and lathe a pop up, then lighten the piston as much as possible...
    Best gains would be transfer work and adjust port timing #'s.
    Then there's additional ports, but we'll save that for another thread...
    Oliver1655 and H 2 H like this.
