MTD Log Splitter
Discussion in 'Chainsaws and Power Equipment' started by Shurdel, Oct 6, 2020.
  1. Ashwatcher
    Ashwatcher
    West By God Viginia
    Why would Cub Cadet, ala MDT, put holes on the inadequate log cradle and not offer to sell you at an up charge a sufficient log cradle? I’m going Lone Wolf I think and the Cub is for sale...I don’t deal well with corporate fraud..My splitter is adequate, not ideal...don’t buy Cub Cadet
  2. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Iron and Oak (Brave) is a solid company but has gone through some ownership changes. Made in the States, parts are available, and there are well-defined models for each type of use (homeowner to pro).
    Their splitters are some of the best around and have a design that just makes sense. The MTD splitters like the one pictured are a variation of that design; full beam, pushplate/wedge bolted with spacers, etc.
    Chvymn99 and Ashwatcher like this.
  3. Ashwatcher
    Ashwatcher
    West By God Viginia
    I agree BuckthornBonnie, Iron and Oak has a strong reputation as a manufacturer of very solid splitters-Lots of good ones out there and some just middle of the road like everything else. Hope you and yours are well.
    Chvymn99 and BuckthornBonnie like this.
  4. Shurdel
    Shurdel
    Southern PA
    B27B31D2-1010-4284-A9E6-351FF5015A01.jpeg E613EB47-1923-48CF-BE82-69F311E07A16.jpeg
    This is what I’m working with now. It gets the job done. I pull it up on car ramps and set the front on a log. It won’t start at the moment, I doesn’t seem to be getting spark.
    Chvymn99 likes this.
  5. brenndatomu
    Have a low oil switch? Those are notorious for causing problems...
    J. Dirt and Chvymn99 like this.
  6. Shurdel
    Shurdel
    Southern PA
    I have to look at that. There is a label that says it will cut off if the oil is low. There is oil in it. I’m not sure where the switch is.
    J. Dirt likes this.
  7. TurboDiesel
    If you can wait till black Friday, thats when you get the best deal at Tractor Supply. IIRC, they'll knock 150$ off.
    J. Dirt and Shurdel like this.
  8. brenndatomu
    There should be a yellow wire coming out of the side of the block...just unplug that (I think)
    There are tons of these engines in service, I'm sure if you google around a bit someone has posted how to bypass the switch if unplugging that wire doesn't work. Obviously you have to keep an eye on the oil level the old fashioned way if the switch is left disconnected...;)
    J. Dirt, JackHammer and TurboDiesel like this.
  9. TurboDiesel
    I think the oil switch just goes to ground to kill the ignition just like the kill switch.
    Tape the wire end so it doesn't accidentally get grounded someway.
    Shurdel likes this.
  10. brenndatomu
    It does, yes...but it also goes through a module that put a delay on the signal to eliminate the engine cutting out every time you hit a bump...those modules will fail too...I think those can be unlugged to test too, but not positive...they used to be cheap to replace, but who knows now, haven't priced one in many years. Then there are some engines that have a 2 wire oil switch...I think one is ground in, and then the other switched ground out, but again, not sure, best to verify with googlefoo...
    The good thing about it is that the ignition system on these engines is simple and not that expensive to replace components if needed.
    TurboDiesel and Shurdel like this.
  11. Shurdel
    Shurdel
    Southern PA
    Thanks, I’ll look when I get home tomorrow!
    brenndatomu likes this.
  12. Shurdel
    Shurdel
    Southern PA
    So, I found out why my splitter wouldn't start. There was a wire chewed off from the coil to the cut off switch. Dang mice!
    JackHammer and brenndatomu like this.
  13. Warner
    Warner
    While all of gods creation have there place on earth I feel mice have been put here to try mans patients! I hate them!
    J. Dirt, Shurdel and brenndatomu like this.
