MS660....
Discussion in 'Chainsaws and Power Equipment' started by Chvymn99, Jan 19, 2014.
  1. MasterMech
    I second that motion but say more bar.
    If you are not a production faller, or cutting firewood to the tune of a few hundred cords a year, then running a modded saw is just because you have an itch that needs scratched. To those guys, time is money, and the uptick in production is well worth any trade-offs in running costs and equipment longevity. And if you don't fit either one of those categories, the cost of running the saw is probably peanuts anyways.
    Back in my dealership days, a pro arborist came in and bought two MS200Ts. Just walked in, told me what he needed and we plopped them on the counter. When I announced his total, which was over $1000, the customer next to him just shook his head and said he couldn't fathom paying nearly $600 for such a small saw. The arborist smiled and said, "No worries man, these will be paid for by noon and I'll still have money for lunch.":rofl: :lol::thumbs:
    clemsonfor and Chvymn99 like this.
  2. Chvymn99
    I'm aiming for a 32" bar.
    I know I see that 7, 8, 9 pins comes up in several different conversations. But sprockets what is it ?
    mdavlee likes this.
  3. MasterMech
    7-8-9 pin is referring to the number of slots in the sprocket.
    Chvymn99 likes this.
  4. Chvymn99
    That's the part that chain wraps around on the saw side? So do you have to do anything special on the tip side? Special chain? I know rookie questions. But I'm a learning rookie....:emb:
    clemsonfor likes this.
  5. MasterMech
    The bar tip sprocket and the clutch sprocket (saw side) must match the chain pitch. They both must be 3/8" or .404 depending on the chain you intend to run. (Most likely 3/8" ;) ) The size of the clutch sprocket in relation to the bar tip does not matter.
    Chvymn99 and clemsonfor like this.
  6. Oliver1655
    Oliver1655
    Central Missouri
    When running a larger cc saw with a shorter bar, some folks will run a larger # of pins sprocket on to speed the rpm. Down side is it will decrease torque. But again, when running a short bar you have torque to spare. I believe it uses an "E clip" with a rim sprocket so changing back & forth should take less than 5 minutes to do. While you have it apart, it is a good idea to slide the clutch drum off & look for any cracks. (The chain brake has to be off to remove the clutch drum.) Be careful to not drop the bearing.
  7. DexterDay
    DexterDay Administrator
    Northeast Oh
    Chevymn99- PM me your Addy and I will send you a new 3/8 8 pin rim sprocket?
    All you need to replace it is a simple pair of needle nose pliers, if you don't have the proper tool to remove the E clip.
  8. MasterMech
    That friggin e-clip can be a bastard to remove if it wears into the washer a bit. It makes it's own recess that makes it tough to pull up and out.
    Keep your hand over it if possible 'cause when it comes off, it's usually in a hurry.
    mdavlee, Oliver1655, Chvymn99 and 2 others like this.
  9. mdavlee
    mdavlee
    Here's the 660. I doubt there's many 460s out there faster than that 660. I wouldn't run anything less than 40:1 in my personal saws. After the 066 crank coming apart with 50:1 that Randy had ported the $.20 a gallon of gas saved for oil isn't worth a bottom end and possible top end replacement. It would only take about 1200 gallons of mix to pay for a bottom end rebuild and topend.
    Ported 460
  10. Chvymn99
    Thanks for posting that video. Theres just something about all that power at your finger tips. Thanks again.
    mdavlee, Oliver1655 and the GOAT like this.
  11. the GOAT
    the GOAT Banned
    Maine
    Great vid; what size bar and chain?
    Looked like about 14 seconds for the 660 vs 20 for the 460...
  12. MasterMech
    Is that 660 stock? I heard removing the air filter cover was good for at least 50%. :p
    And that ported 066 was running 80:1 when it bought the farm. ;)
    mdavlee likes this.
  13. Chvymn99
    No thats the 660 that I bought. Its got ported and MM job.
  14. MasterMech
    :p I meant mdavlee's 660, which I'm pretty sure is also ported. But I didn't know yours was too. The muff mod and porting will definitely address the shortcomings of a stock 660. :cool:
    mdavlee and Chvymn99 like this.
  15. DexterDay
    Northeast Oh
    I think that's what he meant? He bought mdavlee's 660?
    That's the way I read it?
    If so, you got a mean saw. :)
    mdavlee, Chvymn99 and clemsonfor like this.
  16. MasterMech
    Re-read and it does sound that way. In which case please pardon my density! :emb:
  17. clemsonfor
    He did buy mdavee saw!
    Chvymn99 and mdavlee like this.
  18. mdavlee
    mdavlee
    32" full comp and 28" full comp for the 460. He bought that one from me. I run cover less to keep the filters clean longer.
    the GOAT likes this.
  19. the GOAT
    the GOAT Banned
    Maine
    I was confused about who/what saw too!
    But the video kind of throws a wrench in the idea that a 460 will be as fast as a 660 in the smaller stuff.
  20. clemsonfor
    Maybe if the 460 was auto tune? :)
