MS462 Review
Discussion in 'Chainsaws and Power Equipment' started by Oldman47, Jan 30, 2018.
  1. mdavlee
    mdavlee
    If the 462 has the same crappy mounts as a 661 it will be like a floppy hat after 100 hours or so and need new mounts for longer bars. Flippy caps and floppy mounts do sound good together a 372 with the same bar feels more solid than a used 661 did with 110 driver Oregon light weight.
  2. Fabz
    Fabz Banned
    Buffalo ny
    You couldn’t give me a 372xp ! Junk
  3. mdavlee
    mdavlee
    I feel the same about a 441 and 661. Bad husky copies.
  4. Fabz
    Fabz Banned
    Buffalo ny
    Yeah except the STIHL starts and runs everyday and stays intact ... pretty sad when you have to disassemble a brand new saw (husky) and loctite every fastener ! Only husky I own is WWS 395xp ... now That saws’ a runner !!!
  5. mdavlee
    mdavlee
    I dont have oroblems with my huskies starting. I have worse luck running stihls. New 660 I bought lost the e clip, sprocket, and rim on the 2nd cut when I got home. I've lost just as many bolts off stihls as I have huskies. I use loctite on stihls just like huskies. Improper torque is what most lose bolts from.
    Andyshine77 likes this.
  6. Redfin
    Redfin
    central Pa
    461 is a completely different design regarding transfers.
    Fabz and Andyshine77 like this.
  7. Fabz
    Fabz Banned
    Buffalo ny
    I agree ... more of a hi-rev saw as opposed to the torque of a 460
  8. Andyshine77
    Andyshine77
    Cincinnati, OH
    Correct.
  9. Fabz
    Fabz Banned
    Buffalo ny
  10. Andyshine77
    Andyshine77
    Cincinnati, OH
    Again I have no idea where you get this from, the 460 is not a torque saw and they can rev too the moon.
    The 461 has front feeding transfers, likely to slow down the charge and preheat it a little. This helps lower unburnt hydrocarbons. The debate on this and the case stuffer "as I call it" continues.
    I think a some are forgetting fact and opinion are two very different things.
    Moparmyway and mdavlee like this.
  11. Andyshine77
    Andyshine77
    Cincinnati, OH
    That new 462 is only a few ticks behind a ported and broken in 461, that's extremely impressive. I've seen saws gain as much as 20% after break-in.
    Moparmyway likes this.
  12. Fabz
    Fabz Banned
    Buffalo ny
    The 460 and 461 are based on the same platform and do share parts interchangeability.. the 461 has a crank stuffer and has quad transfers with an ENTIRELY DIFFERENT Jug ... this is not an “opinion” sir ... if so inclined check out Hotsaws101 video bench talk showcasing the 460/461 chainsaws ... a link for your enjoyment sir
  13. Fabz
    Fabz Banned
    Buffalo ny
  14. Andyshine77
    Andyshine77
    Cincinnati, OH
    Sir I've ported a 461, and more than a few 460's. It is clear you have no clue what your talking about, and what I said went over your head. Have a good day.
  15. Fabz
    Fabz Banned
    Buffalo ny
    Please explain the sentence “ it is clear you have no clue what you are talking about and ....”. I just provided a link with the saws torn down ... with all due respect sir ... Jack has ported Many more 460/461 series than you have ... I will take his expertise over yours any day of the week and twice on Sunday ! Hawa Rice - Day Andy
  16. Andyshine77
    Andyshine77
    Cincinnati, OH
    Oh good lord, no wonder you were chased off elsewhere.
    Sorry everyone Fabz has been an issue on other forums and has always been argumentative. I will no longer respond to his post.
  17. Fabz
    Fabz Banned
    Buffalo ny
    No loss here sir - the shoulders I stand on are much taller and broader than yours !!!
  18. mdavlee
    mdavlee
    My 46s would tune a good 1k rpm higher than the 461. They both would hold about the same rpm in wood and the 46 would wear it out in a cant
    blacksmith, Moparmyway, Fabz and 3 others like this.
  19. Redfin
    Redfin
    central Pa
    I would like to see a bottom fed quad like the 261 in the 70cc range. Pure speculation as to why they chose to use a front feed in the 661/461 but I do know the secondaries are pooly fed.
    The part of the 462 that intrigues me the most is the crankcase divider between the front transfer port and the rest of the case.
  20. Rope
    Rope
    Alaska
    All that talk will make a fella want to look for a 046 arctic and send it for some magic.
