MS441 vs MS460
Discussion in 'Chainsaws and Power Equipment' started by Woodporn, Jan 6, 2014.
  1. fox9988
    fox9988
    NW Arkansas 72717
    x 3!
  2. GRIZ
    GRIZ
    Old thread but a good one:yes:Words of wisdom:smoke:
    $ooline likes this.
  3. 94BULLITT
    94BULLITT
    Frederick County, VA
    My 441CM was faster than the 660. I put a DP cover on the 660 and the 441 was still faster. I put a 8 pin sprocket on the 660 and then it was faster. I'm sure in bigger wood the 660 would have been faster stock. The RPM's the 441 turns made it tough to beat.
    basod, clemsonfor, splitoak and 2 others like this.
  4. GRIZ
    GRIZ
    I would haft to give you a A+ on that post. :yes: Im running a 8 pin on my ported 441 Do you?
  5. GRIZ
    GRIZ
    My buddy has a 660. I'll do a race with him at some point vs the 441 and get video on my youtube channel. Not sure when, but I'll do it. I don't know how much quicker he'll get through. He's running a 32 inch vs my 25, so it may be more a level playing field than the same size bar[/QUOTE]
    :yes:
    clemsonfor and Chvymn99 like this.
  6. Woodporn
    Woodporn
    S. MA
    if I had thumbs on my feet I'd try racing the 460 and the 660
    Drvn4wood likes this.
  7. DexterDay
    DexterDay Administrator
    Northeast Oh
    Stock for stock? Gonna be close.
    If modded? 460 wins!!! By a lot ;)
    In wood under 25".... Over that, and the 660 shines it's true colors!
    clemsonfor and GRIZ like this.
  8. 94BULLITT
    94BULLITT
    My 441 is stock. It has a 7 pin. I'm not sure if it would have the power to pull a 8 pin.
  9. Woodporn
    Woodporn
    S. MA
    Both are unmolested...
    Am thinking of putting a few $$ into one of them, probably the 460 as the 660 only has like 20 hours on it
    DexterDay, mdavlee and Chvymn99 like this.
  10. Chvymn99
    A good choice....:D
    clemsonfor, GRIZ and DexterDay like this.
  11. Ron660
    Ron660
    NW Louisiana
    Stock 460/461's have more HP than 660's despite what the factory specs say....already proven with dyno tests. After porting, the 660 wins in HP at all rpm ranges.
    GRIZ, clemsonfor and mdavlee like this.
  12. firecracker_77
    firecracker_77
    IL
    Try an 8 pin. It should have the power...especially with a short bar. :D:saw:
  13. SquareFile
    SquareFile
    somewhere
    441 will be happiest with a 7 pin
    GRIZ, MasterMech and clemsonfor like this.
  14. clemsonfor
    Did you post this dyno chart here? Seems like I remember seeing it on here or was it AS?
    GRIZ likes this.
  15. 94BULLITT
    94BULLITT
    A 8 pin might work with a shorter bar but I have a 25'' bar on mine. I don't think it would have the power to turn a 8 pin with a 25'' bar. The 441 is not a real torquey saw.
    GRIZ likes this.
  16. firecracker_77
    firecracker_77
    IL
    Yeah...I have a 25 inch bar and several chains for that size. I have never tried the 8 pin with that set-up. I have the 7 pin in the field bag for when I switch back and forth.
    GRIZ likes this.
  17. firecracker_77
    firecracker_77
    IL
    There's an easy way to find out....For firewood cutting, I love the 16inch bar 8 pin set-up. My friend with a 32 inch 7 pin 660 set-up is happy when I help out on ground work duty during his tree jobs. He thinks that my set-up is a firewood cutting screamer given that a 660 has lower rpm and better torque for felling and bucking large stuff but not great when cutting up smaller stuff or limbing. I score free firewood, and he keeps the cash. A sort of reasonable deal...his wife leaves him to earn all the money, so I help him out any way I can.
    GRIZ likes this.
  18. 94BULLITT
    94BULLITT
    If I'm cutting something small I'll grab smaller saw with a shorter bar. The 034 super is a good all around firewood saw. When I get in something bigger I'll get out the 441 or 660. I really like the smoothness of the 441.
    basod, GRIZ, Chvymn99 and 1 other person like this.
  19. firecracker_77
    firecracker_77
    IL
    I don't have an in between. The 290 lives at my house where I cut stuff around the yard. My 441 is the firewood saw.
    GRIZ, Chvymn99 and 94BULLITT like this.
  20. Ron660
    Ron660
    NW Louisiana
    I think the factory dyno results were on AS but the ported charts were also posted here. Chad did all the dyno tests.
    GRIZ likes this.
