Ms310 muffler mod?
Discussion in 'Chainsaws and Power Equipment' started by jetjr, Sep 14, 2014.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Aaand once again I miss read the title..... I thought this said CS310.:whistle::emb:
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    We know what's on your mind ;)
    Mr. Timberwolf! ! :dex:
  3. clemsonfor
    How ya been pete havent heard from you in a week or so it seems like.
  4. jetjr
    jetjr
    Pa/Md line
    Thought about doing my 330 top handle also if you have any info on this.
    Chvymn99, Pallet Pete and DexterDay like this.
  5. Pallet Pete
    Ovid
    I might... If its anything like my cs310 then there is a cat in the muffler. All I did was drilled the cat out and used a dremel to clean the cat chamber up. Then I added four 1/4 inch holes to the chamber. On the front I took the exhaust diflector off and opened the whole to the full size that would fit under the diflector. It woke that 310 right up.... Shes a screamer now for being a little saw and i lt runs far better! The only issue that it really needs to warm up now for a minute in order to get the fuel flowing. I just hold the throttle until it warms up. Only need to do that once if your cutting all day it will fire every time smooth the rest of the day.
    Chvymn99 and SquareFile like this.
  6. Pallet Pete
    Ovid
    Not bad. Working a lot of overtime... I got on today to 193 notifications and 23 pms lol. Gotta catch up!
    Certified106, clemsonfor and Chvymn99 like this.
  7. jetjr
    jetjr
    Pa/Md line
    MasterMech so I took the muffler off today to get started and than the kids wanted to play. My question is do I need to put the spark arrestor back on?
  8. MasterMech
    The screen is optional. The deflector I highly recommend putting back.
  9. jetjr
    jetjr
    Pa/Md line
    Yea yea should have just said screen. Thought I didn't need it but saw a few pics in the other threads that had them reinstalled. I am planning on taking a little off the deflector too.
  10. MasterMech
    Don't be shy taking material off the deflector. On the 390, I took the entire depressed area out, completely bypassing the baffles inside and cut the deflector back as far as I could and have it look decent.
    jetjr likes this.
  11. jetjr
    jetjr
    Pa/Md line
    Can you recommend a decent tach. I don't fully trust my ears on this one. To many younger years without earplugs.:dex:
    clemsonfor and MasterMech like this.
  12. Cut4fun
    Cut4fun
    OHIO Redneck
    Going to copy paste some info from a thread on CR. So you have some info here on it.
    If I couldnt find a EDT-5 like I have or PET 1000 http://www.npelectronicsindia.com/pet-1000-tachometer.htm
    or OPPAMA PET-1100 Tachometer maker of the older stihl EDT-5
    http://www.amickssuperstore.com/OPPAMA_PET_1100_Tachometer_p/oppama pet-1100 tach.htm
    http://www.amickssuperstore.com/OPPAMA_PET_1000_Tachometer_p/oppama pet-1000 tach.htm
    OPPAMA PET-1000 Tachometer
    If I couldnt get above I would get the one below.
    http://www.amickssuperstore.com/DTI...chometer_Tach_p/dti tech-tach tt-20k tach.htm
    Get a .5 refresh rate tach. The 1.5 sec refresh rate from Baileys and EDT 7-8 are to slow for the money. There is a cheapie tach that is 2.5 sc refresh rate and cost $20-$25, it works, accurate but is slow.
    Older no longer available tachs like the Stihl EDT-5, DET-302, DET-303, Echo-1000 or 1100 (same as EDT-5). If you find one grab it.
    Still available TT-20 and Tiny Tach are all .5 refresh rate and cost $85
    If I couldnt find a EDT-5 like I have, I would buy one of these new. Amick's link below.
    Per a trusted stihl man Lakeside.
    EDT-7 and 8 tachs will work with all previous Stihl ignitions, as well as the new IEM MS 280, and all future models that have dual magnets in the flywheel. All previous tachs including the EDT-5 will not work on IEM units.
    The EDT-7 has a mode button that will allow selecting different engine ignition systems, but this feature is not required on Stihl products. Might be useful on your generator or other engines though...
    The EDT-8 has no mode features, and will work with all STIHL products.
    These tach do not refresh the display as fast as the EDT-5
    I think this is the company that used to make the EDT-5 for Stihl and the Echo 1000. I havent a clue what one would cost or where to get one. looks updated with all the front buttons in pic.
    Links have went bad, need to search for them now.
    This is one of the older made for stihl ones too, was DET 302 . PET 302 http://www.npelectronicsindia.com/digital-engine-tachometer.htm
    See they are selling the OPPAMA PET-1100 Tachometer maker of the older stihl EDT-5 http://www.amickssuperstore.com/OPPAMA_PET_1100_Tachometer_p/oppama pet-1100 tach.htm
    Thread with others shared info on subject. http://chainsawrepair.createaforum.com/stickys-of-how-to-basics/chainsaw-tachometer-choices/
    jetjr likes this.
  13. jetjr
    jetjr
    Pa/Md line
    Since it's only my saw would a cheapy tach with hour meter work. Not looking to spend a lot and hopefully only tune it according to weather.
  14. clemsonfor
    Do a muffler modd on it where you cut that front of the muffler out. You will hear it plenty easy then
    jetjr likes this.
  15. Cut4fun
    Cut4fun
    OHIO Redneck
    It would work but they are so slow to hold WOT 2.5 seconds for a read. Plus has to use wire attached. $20
    I like the .5 read. wireless or wire choice $90
    1.5 to slow for the same money as the .5. All JMO
    jetjr likes this.
  16. jetjr
    jetjr
    Pa/Md line
    I think I am going to go with the tech tach 20.
    Cut4fun likes this.
  17. MasterMech
    I have a Stihl EDT-7, it works, and works well. But the refresh is a bit slow for my liking. If I get another, it's prob going to be the DTI Fast Tach.
    http://www.tinytach.com/handheld.php
    DexterDay likes this.
  18. DexterDay
    Northeast Oh
    Yep.. Same here..
  19. Carbine
    Carbine
    Whos/what tach was that at Swags earlier this year? I liked it..
    clemsonfor likes this.
  20. jetjr
    jetjr
    Pa/Md line
    Looks nice I have not ordered one yet. Think I'll try that one.
