MS290 starting issue
Discussion in 'Chainsaws and Power Equipment' started by Kimberly, Apr 10, 2016.
  1. pantelis
    pantelis
    Europe
    relax ............ not the end of the world
    Kimberly and clemsonfor like this.
  2. pantelis
    pantelis
    Europe
    first try to repair theese that you already have , if not , buy news END OF STORY
  3. MasterMech
    Parts for outdoor equipment is a different game than automotive. You can actually get the same part for a car or truck, especially domestic models, from an aftermarket store like NAPA, Carquest, Advance Auto, AutoZone, etc. no different than OEM except for the price. OPE is different. Some parts are available aftermarket, and some of it is good, some of it is crap. And it isn't easy to tell the difference before you buy.
  4. Kimberly
    Kimberly
    The Kangaroo State
    Here is a story. On the old 93 Buick the motor mount broke. I could still drive the car as long as I was easy on the throttle. I went to Advance Auto and got a new aftermarket motor mount. Took the old motor mount off; jack under the engine, and found out the new motor mount would not fit, it was made the same but the holes would not line up. Here I was, unable to drive the car, too far to try and walk and get parts, and no one that could drive me. So I got out my rotary tool, my drill, and some files, and I went to work doing hand machining to make the holes align correctly. Took me some time but I got the motor mount on the car. I went back to Advance Auto website and there was one review that stated the part was junk, the holes don't align up properly. If I had just seen that review before I brought the part.
  5. yooperdave
    When it comes to reading reviews, reading the good and favorable ones don't help out at all.
    Always read the low rated reviews and look for repeated problems.
  6. Kimberly
    Kimberly
    The Kangaroo State
    I am curious as to what is a good price for a new 20" chain for the MS290?
  7. Eric VW
    Google it. Plenty of choices.
    pantelis, Barcroftb and Kimberly like this.
  8. DexterDay
    DexterDay Administrator
    Northeast Oh
    I agree.. For parts, but runs? That's $100- $175 all day.
    I wish you luck Kimberly. But for such small part (and a detrimental part, that is used a lot) OEM would probably be best. As MasterMech stated, the OPE world is different (sorry about your Buick).
    clemsonfor, Barcroftb and Kimberly like this.
  9. Kimberly
    Kimberly
    The Kangaroo State
    This one stated: Stihl ms290 with 20 inch bar and chain. Does not run for parts only
  10. pantelis
    pantelis
    Europe
    how often you cut woods ?? soft or hard , forest conditions or house backyard ? put all theese and make your choice
  11. clemsonfor
    For a stihl chain you will pay around $25 @ stihl. You can get an aftermarket chain on ebay for around $15. Some chains are junk some are better. I have found forester chains work but for the money spend a dollar or so more and get an oregon.
    bobdog2o02 likes this.
  12. clemsonfor
    Been there don't that. I put a motor mount in the saturn. I had to lift and torque the motor more than it should have gone to fit it in there. But it did and it worked just had the engine sitting slightly higher than it should have . It worked and was in there like 4 years after I installed it and is probably in it still to this day.
  13. Kimberly
    Kimberly
    The Kangaroo State
    OK, I have several used chains and they may do me well. I saw a seller that was selling a Stihl chain in the box for $20. I have no idea about these things.
  14. clemsonfor
    $20 for new stihl chain is a good price. Esp for a 20" chain.
    Watch out there is lots of people who sell once used dull chains on ebay. Nothing wrong with them if there not badly rocked but you will have to sharpen them, so knowing that going into it. I might pay $10 a pice for a good once used chain...possibly a few dollars more. But I grind all my chains and I can have one sharp in 10 mins or so.
    Kimberly likes this.
  15. Kimberly
    Kimberly
    The Kangaroo State
    I must have been tired last night, that chain is actually $22.something. I just wanted to know so I can spot a bargain.
    I think I will take the recoil starter to my brother-in-law this evening. He restores old cars and has a fully equipped shop with an impressive array of tools.
    clemsonfor likes this.
  16. jon1212
    jon1212
    Utah........ugh!
    Are you using a new spring clip as well?
    Personally, I would check finish on the new pawls if everything else appears to align correctly. If there is too tight of tolerance between the pawl(s), and spring clip, or between the pawl(s) and recoil housing, some light sanding around the barrels of the pawls with very fine sandpaper may be enough to get things in working order.
  17. clemsonfor
    I'm sure you can make it fit. But will it be worth your time you will need that decision after a quick look over and a few tweaks.
  18. jon1212
    jon1212
    Utah........ugh!
    Kimberly it looks like the 330T will be doing yeoman's work until the MS290 issues are resolved.
  19. Kimberly
    Kimberly
    The Kangaroo State
    Hello, I was thinking about you; actually every time I see my saw you gave me. Big Hugs.
    Yes, new spring, pawls, washer, and pulley.
  20. Kimberly
    Kimberly
    The Kangaroo State
    I need to go out and do shopping so I figure why not have my B-I-L take a look; nothing lost at this time. If I do have to buy new parts then so be it; lesson learned.
