MS290 starting issue
Discussion in 'Chainsaws and Power Equipment' started by Kimberly, Apr 10, 2016.
  1. clemsonfor
    Won't fit in the flat rate box. Maybe one of the regional boxes but those are not availible to ship everywhere, only certain regions.
    If we were to do this I would get you a label and email it to you. Both those places will pick up at the house. I can get a discount through my ebay and or USPS account .
    Kimberly and HDRock like this.
  2. HDRock
    Manual says 13 pounds PH,
    10 people 5 bucks, covered
  3. brenndatomu
    Less $ if the B/C is left off...
    MasterMech, Kimberly and clemsonfor like this.
  4. HDRock
    Bar and chain is not needed anyway
  5. Kimberly
    Kimberly
    The Kangaroo State
    I will help pay as well.
    HDRock likes this.
  6. clemsonfor
    • It would be cheaper than $50
    I am thinking it could be shipped to me for less that $17 one way by feD ex just thinking of the last few shipments I have sent.
    I just sent 11 pounds from here in SC to Southern Cal for $25.
  7. HDRock
    All you need is a zip you can figure it out
    Kimberly likes this.
  8. HDRock
    I know you are frustrated about this Kim, I would be too
  9. clemsonfor
    Yep. Also need a closer weight than what the manual says...Unless we want to go with that which is probaby close enough cause usually the shipping goes up by the half pound anyway.
  10. Kimberly
    Kimberly
    The Kangaroo State
    The last thing I shipped by FedEx was a desktop computer that my friend got me to repair; he paid for the shipping both ways from/to Texas and it was not cheap. The guy at the FedEx told me that the size of the package makes a difference as well and he did measure the box to calculate shipping. I would want to protect the saw but keep the size of the box down. I may have some sheet styrofoam I could put around the saw for protection. I need to see what boxes I have on hand; I save boxes; will visit my sister tomorrow; will see what boxes my BIL has as well.
  11. clemsonfor
    Ok I just thought of something.
    Pull the recoil back off. See if that coil is tight in the saw?. Make sure the screws are tight and that it is not hitting the flywheel.
    HDRock likes this.
  12. clemsonfor
    Find a box slightly larger than the saw. Then cut cardboard to fit inside all sides...basically double boxing it in cardboard. And then put plastic bottles around it or paper or somethingsimilar.
    Like I said I shipped a 35 pound battery charger In a box just slightly smaller than the power head would need to go in and I paid like $17 to ship fed ex to South LA.
  13. Kimberly
    Kimberly
    The Kangaroo State
    OK, will do that tomorrow. it was not hitting the flywheel when I checked it earlier today but I did not try to wiggle the coil.
  14. clemsonfor
    You will see marks on the flywheel if it's hitting. They usually will hit just on the magnet when they juse barely start hitting.
    HDRock and Kimberly like this.
  15. Kimberly
    Kimberly
    The Kangaroo State
    OK, I will inspect it tomorrow. I need to call it a night and get some sleep. Thanks guys for your help; it is really appreciated. Big Hugs.
  16. HDRock
    That could cause it, what's the gap on that, like, ten, fifteen thousands?
  17. clemsonfor
    I am not sure what it is, but i think it's a good thick piece of paper or maybe just normal paper thickness.
    I think the ones I have done usually have a piece of paper that you put between the two then pull out.....basically it's CLOSE!
  18. brenndatomu
    I'm sure there is an actual spec for the gap, but when I fool with 'em I usually set it at 0.020" and have had no problems (a matchbook cover is supposed to be ~0.020" BTW)
  19. Kimberly
    Kimberly
    The Kangaroo State
    I checked the coil, it is not hitting and appears to be tight.
  20. clemsonfor
    Well dang it. That's a good thing though but if it was loose and touching we would of found the issue.
    I had a husky 372 that was acting wanky and wouldn't run right and I'm thinking would have a rough spot in the start. Well I looked and one of the screws was gone and the flywheel was crashing into the flywheel. It had pretty much destroyed that coil, so I pulled one ofF a parts saw and was good to go again.
