MS290 starting issue
Discussion in 'Chainsaws and Power Equipment' started by Kimberly, Apr 10, 2016.
  1. Mag Craft
    Mag Craft
    South East Wyoming
    Well I would say it is time to get a volt meter out and start checking to see if you have voltage to the coil or you could use a dwell meter and see if you get a reading when you turn it over.
    Kimberly and HDRock like this.
  2. MasterMech
    It's not designed to be replaced but that doesn't mean you can't do something (creative) about it. On the flip side of that, buying an aftermarket starter assembly for $30 or so might be the way to go unless a pristine used OEM one lands in your lap.
    Catching up on some narrow paperwork eh?
    (Fixed that post for ya too.... :p)
    Eric VW and Kimberly like this.
  3. Kimberly
    Kimberly
    The Kangaroo State
    OK, question for MasterMech and others. Would you suggest buying a new aftermarket recoil or a good used (was told "All in great shape. No problem with them. Very little use") recoil? Price is actually a bit cheaper on the new after market than the used Stihl. There is a return period on the used recoil.
  4. Kimberly
    Kimberly
    The Kangaroo State
    I just started the saw and there was no problem with the recoil. I intend to use the saw today and see how it does before I make a decision to replace the recoil or not. Would still appreciate an opinion on new aftermarket or used OEM.
  5. clemsonfor
    I'D buy the used low hour OEM
    But didn't you say the issue occurs "sometimes"? Which I would take to mean it does not always do it, which would explain it working now.
  6. Kimberly
    Kimberly
    The Kangaroo State
    Well, sort of. I noticed one time after putting in the new spool/pulley and pawls that it was normal, but then it return to the hard. That is why I want to use the saw a bit and see before I make a decision to spend more money on it. It may be OK and not go back to the hard to pull; I tend to cut the saw off when carrying it so I will start it a few times while working. Was getting ready to go cut when it started raining so that may have to wait and I can look at getting the tractor running.
  7. yooperdave
    You next year if you don't get that saw fixed!
    Hammy, saskwoodburner and Eric VW like this.
  8. brenndatomu
    Can't like that...too skeery!
    Hammy, Eric VW and yooperdave like this.
  9. Kimberly
    Kimberly
    The Kangaroo State
    I am using The Beast today and it was hard to pull; or jammed, twice during the starts. I asked MasterMech and any others opinion on if I should buy a new aftermarket or a good used OEM; prices are about the same.
  10. Kimberly
    Kimberly
    The Kangaroo State
    :bug::eek:
  11. Mag Craft
    Mag Craft
    South East Wyoming
    Clearly it seems to me that something is jamming up in the recoil assembly when under pressure of pulling it when attached to the saw. I think if it were me that I would replace the entire recoil assembly because the old one could just be worn out. Replacing parts could be throwing good money after a bad recoil. I would just do an aftermarket recoil. I use aftermarket parts all the time from pistons to cylinders and seals and covers with no issues.
    If you can get a good used OEM than go for that.
  12. MasterMech
    I have no experience with aftermarket starter assemblies but if the price is similar, I would take lightly used OEM stuff every time.
    I have been trying to give aftermarket parts a chance but for the time being, I am done with aftermarket fuel filters and lines. I have never been able to successfully use aftermarket filters or molded fuel lines (i.e. Stihl MS250, 290, etc). Just had an MS250 come back in that had an aftermarket fuel line installed about a year ago. Already cracking near the tank grommet and leaking. That's the last saw I used an aftermarket line on and the three others have already had the junk swapped out for OEM.
    Barcroftb likes this.
  13. Mag Craft
    Mag Craft
    South East Wyoming
    On the fuel lines I will not disagree with you. But there are many aftermarket parts that work just fine and Stihl is not above raking us over the coals for their parts.
    clemsonfor likes this.
  14. MasterMech
    I've used plenty of aftermarket "hard parts" (Pistons, cylinders, bearings, cranks, even seals) to great success. I've tried an aftermarket tank assembly for an MS250 and it made it two weeks and two comebacks before it got swapped for used OEM. Didn't fit well, required quite a bit of hand massaging to get it installed, and then something was wrong with the oiler bore and it would not hold the pump properly.
    OEM pricing has been getting better, unless it's a cosmetic item. Those things are still awful expensive. And it's not just Stihl. ;)
    Mag Craft likes this.
  15. Kimberly
    Kimberly
    The Kangaroo State
    I went to my sister's house to cut up the dead tree; it turned out to be a tulip poplar; maybe still good, will know more when I split it.
    Together with the work at my house I started The Beast maybe a dozen times and had it to jam three times. Should I just wait and see how it does or think about going ahead and replacing the recoil; money is not that available for me.
  16. clemsonfor
    I have had an AM fuel line split right at filter or just above as well. Second one is been doing fine. Have a tank on my 650 I am very happy with fit and quality.
    Mag Craft and Kimberly like this.
  17. clemsonfor
    That's a 25% failure rate. On your income I would leave it. But if it were me I'd buy the light used OEM. 25% is not that bad really. Not like it's everytime.
    Hammy and Kimberly like this.
  18. yooperdave
    Easy answer. If no money is available for you, and the saw starts, forget about it until the money is there.
    Sorry for my abruptness. :p:D
  19. Kimberly
    Kimberly
    The Kangaroo State
    yooperdave she more or less gave up the ghost today. I cut up that tree I pulled down and some other things and at the end it didn't do anything but jammed. I could also hear the pawls slipping in the what's it. Could be the aftermarket parts I put in it. So, it time to look at replacing it and the consensus appears to be to get a good used OEM.
    Hammy likes this.
  20. Kimberly
    Kimberly
    The Kangaroo State
    I purchased a used OEM recoil off of ebay last night, $26.95 with the shipping. The seller said the recoils they sold came of little used saws. My guess looking at what they had for sell is that they take saws; all brands, and strip them down for parts. I will know when I have the part in hand; they offered a 30 day return so I will have time to use the saw and see.
    Thanks everyone for your help.
