MS 241 hesitation
Discussion in 'Chainsaws and Power Equipment' started by foragefarmer, Oct 8, 2014.
  1. Mastermind
    Mastermind
    Tennessee
    A new carb might not come with the module. I'm really not sure.
  2. MasterMech
    How friendly are you with your dealer? It's not unheard of for Stihl to cover the cost of parts for a failure like this that's technically out of warranty but clearly a manufacturing issue. Just takes a little extra effort/phone call from your dealer usually.
    Chvymn99 and $ooline like this.
  3. MasterMech
    Mastermind
    Thanks for chiming in with the knowledge/experience here Randy!
  4. MasterMech
  5. foragefarmer
    foragefarmer
    Central, Virginia
    It is not the module; Stihl calls it a solenoid. I have had the carb apart twice. I left the air filter and the piece the filter attaches to confirm what the saw is doing and sure enough it is puking huge amounts of fuel out of the carb. At this point lacking the software and ability to plug into the diagnostics port I have thrown in the towel on it and am going to take it to the dealer which irks me to no end. It is a lot like when the ABS on my 3500 crapped out and I knew one of the three sensors was bad, but a standard code reader won't pull the code since it is a separate system, so had to pay someone to fix it. At this point I think it is the coil pack, but thinking and knowing....
  6. foragefarmer
    foragefarmer
    Central, Virginia
    I was going to weigh in on this when everything was said and done. I have been extremely busy.
    DexterDay likes this.
  7. Mastermind
    Mastermind
    Tennessee
    So far the only other M-Tronic saw that I've known of to have issues.......was also a 241. It had a bad coil......and just quit running.
    MasterMech and DexterDay like this.
  8. CBeal34
    CBeal34
    Maine
    Foragefarmer, did you resolve the hesitation issue & if so what was the fix? I picked up a MS241 a couple weeks ago and through the first 2 tanks it's doing what you described, almost like it's flooding out. Idle time between cuts doesn't matter, if the chain stops it is going to bog & you have to gradually throttle up to make the next cut. I tried the 90/90/5 cut thing mentioned on the 1st page & no change. It's back at the dealer now.
  9. Mastermind
    Mastermind
    Tennessee
    Almost without exception, it's the solenoid on the carb.
    Gunn and Kg461 like this.
  10. CBeal34
    CBeal34
    Maine
    Thanks. If the dealer doesn't come up with a solution, I'll buy one & replace it.
  11. Woodrat1276
    Woodrat1276
    Ky
    Just posting to keep up with results
  12. pantelis
    pantelis
    Europe
    :D:DThe dealer for sure will give a solution just because the only think that they know to do is to change new parts with other new parts , even if only a untight screw is the solution of the problem . STIHL thank you for your support .........................
    concretegrazer likes this.
  13. pantelis
    pantelis
    Europe
    Friendly dealer ???? yes always with the stihl
