Mower deck maintenance. Is it worth it?
Discussion in 'Chainsaws and Power Equipment' started by The Wood Wolverine, Jun 2, 2024.
  1. Haftacut
    Haftacut
    Rives Junction, MI
    Just got a new mower and contemplated putting a product on the bottom of the deck that keeps grass from sticking and makes it easier for it to come off. Did some research and seems from peoples experience that it’s not necessarily worth it. I know with my property I’m just gonna plan to do what you do every couple years. It’s what I’ve done with my previous mower in the past too. Mostly gravel driveway and sandy soil usually sandblasts whatever is put on the bottom of the deck whether paint to protect or other products that repel.
    Horkn, Screwloose, eatonpcat and 3 others like this.
  2. brenndatomu
    If I'm coating a deck that is still in good condition, I'd try to find a 2 part epoxy coating...if rusty then I'd lean toward POR15
  3. MasterMech
    Phew - wish there was a simple answer to all that. And best practices can vary by region since different conditions make different problems. In the northeast, and likely the PNW as well, rust is the primary killer of decks. And that comes from not cleaning the undersides of the deck - religiously. I have never seen a mower deck (in constant use) that was washed out after each cut have anything other than very light surface rust under it. It's the sticky rye and blue grasses that are typical to the NE and PNW that build up under the deck, even if the grass is "dry" when cut. Rotary mowers tear the gras, and that juicy, healthy grass, sprays moisture while the mower blades commit assault and battery. SHARP mower blades help a BUNCH but you can't fight Mother Nature on this one. The golf courses wash down their equipment every day it goes out. They cut in the dew and the rain, and their stuff lasts for decades and thousands of hours of use. Seals may or may not be a little more robust on equipment like that but one thing I saw that consistently made for excellent performance, was a good grease that was intended to perform in wet environments. Ie: Marine grease, or boat trailer wheel bearing grease. It's not hard to find, I'm a shameless AMSOIL fanboy and love their flavor, but you can find it under many brands, on the shelf at any Tractor Supply, auto parts stores, and even Wally World.
    Under a mower deck is a very abrasive environment in any area of the country, but especially so in areas with sandy soils, desert regions, or even just having a dry summer season. Most paints and paint-like coatings don't stand a chance. When I worked for a Deere dealer, I was blown away when I learned how many replacement mower decks were sold for machines under 10 years old in some areas. It was just typical to wear through a deck made from 12ga steel or thinner (as is typical to many residential-quality machines). Some commercial operators were destroying 7ga fabricated decks just through (lots of) normal use.
    Once a deck starts to show cracks around stress areas, it's time to make a doubler plate and weld that in. Make sure you are doubling up the general area around the stressing component, not just the crack. Sometimes adding gussets to factory fixtures like gauge wheel brackets, or main hangars, is great insurance. A reinforcement ring for where the spindles bolt on - etc. Your time and tools usually dictate how far it makes sense to take it.
    Screwloose, RCBS, WinonaRail and 7 others like this.
  4. The Wood Wolverine
    Sage advice, I appreciate the response. I should probably look for a spare deck now so when the time comes it won’t be a hard find or super expensive.
  5. Mrxlh
    Mrxlh
    Dat Boot
    If it’s too small to need a chainsaw, it gets mulched in my yard…. Maybe the reason my deck stays somewhat clean???
  6. MasterMech
    I did a lot of "bodywork" to mower decks back in the day. :D:BrianK:
    Screwloose, RCBS, eatonpcat and 3 others like this.
  7. RCBS
    RCBS
    Over here
    Those old decks musta been made of beer cans. My old man was always super sensitive about his hitting a stick or rock. Part of the reason I bought a 'tank' of a mower I suppose.
    Finally got to use it again last night. Pure luxury compared to the rider (bx2380)! Suspension seat! :sir: Approximately 25 minutes quicker to finish and I wasn't even trying.
  8. The Wood Wolverine
  9. FarmerJ
    FarmerJ
    Minnesota
    Our ground is so sandy, doing anything is pretty pointless other than not letting the grass accumulate on the deck.
    I’ve bought a new mower simply because it was cheaper than buying a new deck. The sand just eroded it away like a sand blaster
  10. MasterMech
    They were actually. Wheelhorse, Deere, MTD, AYP etc. All of them before the mid 90's were pretty "flexible" actually. Not very tolerant of abuse or even "oopsies". The metal didn't get any thicker in the 90's, but the manufacturing sure did, especially for Deere post-'92. I think the 38" decks on the STX 38, and the 100 series (160/165, 170/175, & 180/185) were some of the first good, sturdy, mower decks on residential grade machines that I can remember and while nostalgic, nobody really missed the earlier designs like the 37", 46" or 50" decks that were so common under the 200/300 series garden tractors. The mower decks were glaringly fragile compared to the tractor with those models. The 46 sure did hang around awhile though! Could get it (new) as late as Y2K on some Sabre/Scotts models that were based on the STX 46. Wheelhorse unfortunately always had a relatively weak mower deck under a bomb-proof tractor, and that was part of their undoing IMO. As the '90s progressed, the industry ran (not walked) towards mowing performance and productivity (and operator ergonomics) vs tractor versatility and durability. Hence the rise of the residential zero-turns. Pretty pathetic as a "tractor" but mows circles around just about anything else.
    Gotta get a "Jungle Jack" for those. Super versatile tool if you need to lift many kinds of mower on the regular. Commercial walks, ZTRs, even lawn tractors although there are better lifts if you are just dealing with a tractor. But the JJ takes up a LOT less room when not being used.
    Jungle Jack Lawn Mower lift Version 2 – Jungle Jims Accessory Products (junglejimsap.com)
  11. RCBS
    RCBS
    Over here
    I know of a shed. It has 3 Wheelhorse mowers in it. One from each decade 70s to 90s. They are all in as good of condition as they could be after being used for 10 years. Someday a collector will probably be happy. May even be some attachments as well.
    As far as decks go I can't really take a stamped deck seriously anymore.
  12. eatonpcat
    I have a little 704 in my barn...she has been sitting for 30 years. More of a mouse house than a tractor.
  13. Deererainman
    Deererainman
    Union City Ky
    No pictures of the deck, but I do the same at the end of every season. The mower I use is from the early 80's and with no rust holes. I'd say it's worth the time.
  14. ironpony
    ironpony
    Mid Ohio
    So, IMO, using anything to coat the deck is an exercise in futility. Between the blade tip speed, the dust , dirt, etc. add in some moisture and you are basically blasting the finish off that you lovingly applied.
    The moist grass left on the deck is what is going to cause the most problems. Cleaning the deck regularly will cut down on that. Light surface rust is to be expected and a mowing cycle will clean most of that up.
  15. Horkn
    My deck on my 1984, 40 years old this year Ariens, is still in good shape. It needs some paint on the top but it's solid still. I just charged the deck belt that was original. That only went probably because the idler pulley bearing lost all of its balls. It was running like that with no breakfast for a while, there were some good witness marks. Screenshot_20240729-231402.png Screenshot_20240729-231503.png
    Hopefully I'll be able to get a zero turn mower for next year. Then I can use the Ariens GT as a wood hauler and snow blower.
  16. Horkn
    POR15 makes a top coat. It works great. I used it on my ski boat trailer. POR-15 TOP COAT
    I need to paint the fenders and get/ make new fender brackets for my ski boat trailer. I'll probably paint the deck (top) with leftover paint from that.
  17. MasterMech
    Some of the best deck designs ever built were/are stamped. Residential or commercial equipment. It's not how it's made, but what it's made of that matters, along with the final finish. Plenty of cheaply made fabricated decks on the market claiming to be better than a stamped design. And they just.... aren't. Fabricated decks can be great, both in performance and durability, BUT, they came about because fabricating a HD mower deck from 1/4" flat stock takes a paper print (or a fixed jig, if you fancy) $2k welding machine and a welder making $30/hr whether you are building 1 or 10,000. A small to medium OEM could complete an entire season's production run before approaching what it would take to develop the die needed to stamp ONE deck from 7 gauge sheet. Forget what a 1000+ ton press would cost. Stamping makes a lot of sense, for performance. But you need huge volume for it to work economically and only the largest OEMs can afford the risk if there are hiccups along the way.
    Commercial Mowers | 7-Iron & Mulch On Demand Mower Decks | John Deere US
    Horkn, RCBS, Screwloose and 2 others like this.
  18. eatonpcat
    I will stick with my fabbed deck, but I do agree with a lot of points in your post!
  19. brenndatomu
    I agree...my experience has been stamped decks die one of two deaths (or both) rust, or cracks.
  20. MasterMech
    There's nothing wrong with them. Exmark's UltraCut deck will out-cut the best of them in all but the worst (wet) conditions and take as much or more abuse. But there's this narrative out there that a fab'd deck is a better performing, more durable deck and that stamped decks aren't even worth looking at. And that's just as silly as saying you need a V8 to tow heavy or go fast. (Inline 6's would like a word...)
    Especially in the residential equipment market, for a machine that only I am operating, I'll take a better performing deck any day over one that's made from thicker materials, but of inferior design.
