More questions on soapstone stoves
Discussion in 'Modern EPA Stoves and Fireplaces' started by mike bayerl, Dec 25, 2014.
  1. Highbeam
    Highbeam
    I would like to add a nice pellet stove to the house. The pellet gives you smoke free "stealth" burning. Steady heat, and thermostatic heat during the shoulder seasons. Plus, I know women can do it but my wife leaves wood burning to me. She could load a hopper. Oh and many pellet stoves give you longer burns at higher outputs than my BK. Doug fir pellets in my area are still under 200$ per ton.
  2. BDF
    BDF
    Are those flue temps. inside or outside (using a probe or a magnetic thermometer on the outside)?
    I am assuming those are internal temps. 'cause at 1,000 F the steel would be a bright red and sorta' scary IMO.
    Brian
  3. Highbeam
    Highbeam
    Flue gas temps of course, measured with a probe but not a fancy digital thermocouple. I saw that hearthstone run the probe meter up to 1200 more than once. The folks with thermocouples did some testing to find that once you get over 1000 that the condar probe meters were about 10% off.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    I have to agree with you on the condar probe thermometer, mine is a cat therm and I'd say it's off maybe more than 10%.
