More info on Woodstock's new stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by Backwoods Savage, Nov 13, 2015.
  1. Backwoods Savage
    Some betas will have double and some single glass. It is an experiment. Won't know what the final version will turn out like just yet.
  2. Backwoods Savage
    It more than efficiency. It is also about clean air. For sure think of those areas that have inversions and then know that clean burn can mean a lot. It also is about showing that it can be done and doesn't have to be a huge expense to build the stoves so they burn clean.
    Huntindog1 likes this.
  3. Backwoods Savage
    An experiment.
  4. Todd
    Todd
    NW WIS
    Changing out that double pane glass gaskets are a pita! I also don't think it makes my glass any cleaner than any single pane stove ive had.
    There may also be a safety factor involved. If one or the other cracks you can still burn until you receive a replacement.
  5. chucker
    chucker
    New York
    i can't see how the double glass hurts, save costs, and they aren't over charging in the first place. maybe the thrust of the franklin is for cost containment and the smaller size and then single glass could be offered cheaply enough to attract a certain customer.
    for almost any purchase i am looking for two things. first, not to over spend. i went for echo instead of treating myself to a stihl or husky. then, i'm looking not to under spend, and went for the cs600p over the cs590, or cs400 which would have been an adequate saw but not nearly as good, there's your extreme penalty for not forking over the extra couple hundred. that's me and i guess sober headed buyers aren't the whole market and you have to have something entry level.
    on a performance basis i would think the double pane has to be doing something pretty positive.
