More and more
Discussion in 'Modern EPA Stoves and Fireplaces' started by papadave, Jan 15, 2016.
  1. TurboDiesel
    you have an OAK on your stove?
    Eric VW and papadave like this.
  2. papadave
    Yep. There's existing insulated flex duct up there with an inline blower, but the blower quit working, and the flex duct is crumbling. It also has quite a buildup of "stuff" inside from many years of use. It won't be used again, so the whole shebang has to come out and new in.
    That costs money and time I don't have right now though.
    Besides, I'm still workin' on the stove room.
    Eric VW likes this.
  3. papadave
    Yep, put that in last year.
    There's a write-up in here somewhere.
    Eric VW and TurboDiesel like this.
  4. TurboDiesel
    Thought you did, couldn't remember,
    Did it help alleviate drafts?
    Eric VW likes this.
  5. Woody Stover
    Woody Stover
    Southern IN
    Stove's not ideally located in the center of the house, for sure. I know about that from my MIL's house where the Buck 91 is. In addition to retaining heat longer and moderating swings in room temp, another advantage to better air-sealing and insulation is that more heat will make it to the far reaches in your layout. Good work, Pops! :cool:
  6. papadave
    Yep, although the doghouse air and secondaries pull from the house.
    I keep thinking how nice it would be to put the stove right in the middle of the wall where I have the 32' notation. Blower would push air straight to the back of the house without much obstruction.
    We'd also gain the use of the whole stove room.
    Woody Stover and Eric VW like this.
  7. NVhunter
    NVhunter
    Northern Nevada
    How would I foam seal the rim joist of my basement with it being finished with drywall and texture on the ceiling?
    I was thinking about drilling a small hole (big enough for the straw on the can of foam to fit into) and then sealing the hole back up with patch afterward...
    Any ideas?
  8. Kimberly
    Kimberly
    The Kangaroo State
    Yes, before they put the roof sheathing on. Remember this house was built on an assembly line indoors.
  9. HarvestMan
    HarvestMan
    Southeastern Michigan
    That would be a challenge. We were fortunate to have a drop ceiling in the finished part of our basement so we could remove the tiles all along the edge for the installer to apply the foam. It is quite amazing stuff - whatever it clings to becomes stronger when the foam cures and hardens. The installed told me that when applied to ceiling trusses and the drywall ceiling, he could walk on it and not concern himself about stepping on the trusses. Not sure this is a great idea, but it does say something about the strength of the final product.
    If I ever build a house in the future, I would want to look into using this more than the small amount I have in my current home.
  10. papadave
    Didn't they put in an access hatch somewhere....like a closet?
    That's pretty odd, but I have no experience with Man. homes.
    Eric VW likes this.
  11. Kimberly
    Kimberly
    The Kangaroo State
    No, not in this house. In fact, I doubt if one would be able to move between the trusses used, not a lot of space.
  12. Eric VW
    papadave, aside from needing to update our insulation do you or any other members think that rock wool insulation around the section of our chimney thru the attic space would help keep the chimney from shedding heat to that unconditioned space? I'd like to enshroud the exposed out-of- roof portion with aluminum sheet metal and a layer of rockwool- we have a 16 x 16 chimney block + terra cotta flue liner chimney and the top most section is where the most crud collects, as it is cooled by the winter temps....
    Any thoughts?
    milleo and papadave like this.
  13. Locust Post
    I'll sure agree on insulation, I blew in 50 bags in the attic last year, what a difference. My roof will stay snow covered much longer than the neighbors and another noticeable difference is how long the heat stays in the house. Windows are on the list.
  14. papadave
    It's a bit more expenive, but I'd like to use some of that "ComfortBatt" rockwool around the attic insulation shield in the attic. It looks to be easy to cut and form around that.
    I notice more snow melt above that penetration than anywhere else, and it's already been insulated to R-49.
    Backwoods Savage and Eric VW like this.
  15. ranger bob
    ranger bob
    Leeburn Ontario
    Totally agree Dave. For an average house the effort can reduce heating/cooling requirements by a whole lot. Doors, windows, insulation are investments that make a huge difference. Once it's done the wood stove will be able to do it's job easily and less wood consumed.
    papadave and TurboDiesel like this.
