Moment of stupidity cost me a day of cutting.
Discussion in 'The Wood Pile' started by grandgourmand, May 21, 2017.
  1. Horkn
    I forgot about that. I would think it would eventually just mix and you'd probably never know the difference.
  2. billb3
    My old Grand Am fuel pump recirculated quite a lot of gas . Supposedly twice what the injectors needed so they'd never fuel starve.
    When I drove 30 miles the gas in the tank would warm up affecting the sensor . I often had more gas indicating in the tank at the end of that 30 miles than when I started. When I first got the car I thought someone was siphoning my tank at night. There'd be quite a bit less gas in the tank in the morning than at night when I got home.
    Hammy and Backwoods Savage like this.
  3. NH mountain man
    NH mountain man
    WMNF N.H.
    :doh: "that Boston team?" :hair::hair::picard:
  4. MikeInMa
    Hey hey hey.... Easy on "that Boston team".
    Sent from my XT1030 using Tapatalk
  5. grandgourmand
    grandgourmand
    Ontario
    Heh heh...thiught I'd flush out the Bruins fans. I'm just bitter you guys got Chara and we kept Redden. Worst GM decision ever!
  6. grandgourmand
    grandgourmand
    Ontario
    The tank holds nearly 23 gallons. I only put in about three. All i've read on the net is not to drive the car, or start it even. Can ruin the engine.
  7. Chvymn99
    That's what I was thinking... I couldn't remember if it was gas on into diesel or diesel into gas... that was the bad one. Glad to hear that you caught it.
  8. MikeInMa
    He's been good, helping the Bruins win the cup in 2011.
    However, you can take the big guy back. Age has reduced him to slow and plodding. Still has his reach and can log lots of minutes, though.
    He's well into the back nine of his career.
  9. grandgourmand
    grandgourmand
    Ontario
    Diesel into gas is ok. Or not as bad.
  10. Backwoods Savage
    Either way, mixing that stuff is not a good thing for motors. I've seen it happen. Now, I have put chain saw gas in gas engines but that is no problem.
  11. Screwloose
    Screwloose
    I poured 5 gallons of kerosene into a old Ford pickup once........ Realized what I did and filled it full of gas. Ran pretty crappy on that mix but it ran.
  12. wildwest
  13. Boomstick
    Boomstick Banned
    Saratoga county ny
    That actually makes alota sense to me!
    I thought it's kinda brilliant!
    I would think sloshing around while moving would mix it.
    Maybe if you just moved over to a diesel pump and over filled it gas would pour out!
    There are resistor fixes for that. Plug inline to correct for the voltage offset!
    NH mountain man, Hammy and billb3 like this.
  14. billb3
    LOL. That was 1989. It's likely a washer and dryer by now.
    Hammy likes this.
  15. Oldman47
    Oldman47
    Illinois
    Nope. The diesel and gasoline will mix easily. You won't drive 5 miles before the gas/diesel mix is completed. This is especially true since many diesel vehicles use a recirculation system to keep the fuel warm in winter by bringing heated fuel back to the tank to mix in and keep the tank sort of warm.
  16. bearverine
    bearverine
    Winchester, Indiana
    If gas and oil wouldn't mix it'd make it hard to run a two cycle saw, wouldn't it? ;)
  17. yooperdave
    Yup. And the fuel would separate from the oil after any unused period of time according to that also.
    there just doesn't seem to be an easy quick fix for mixing diesel and gasoline!
    Backwoods Savage, Hammy and Eric VW like this.
  18. HDRock
    I found out , chainsaw won't start at all ! when ya put oil in the gas tank and I don't think the gas I put in the oil tank would lube the chain very good :whistle::headbang:
  19. yooperdave
    :doh:
    I'm sure you're not the first one to do that!
    I came real close once to the same thing myself...caught it just before I started pouring!
  20. Oldman47
    Oldman47
    Illinois
    My tree guy was using a Stihl 193T to cut limbs off my tree and I commented that it would be easy to get it wrong. He just smiled and said that once you learn your equipment that just doesn't happen. It made me wonder how long it took him to learn his equipment.
