Moisture Meter Recommendation.
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Mar 2, 2020.
  1. buZZsaw BRAD
    Gave my MM to my friend yesterday as i wasnt that happy with it. Had four different settings for different density woods.
    Whats everyone else using? Looking for something on the cheap. My old one.
  2. The Wood Wolverine
    I use the cheapie Harbor Freight one. I’m typically burning 3 years seasoned wood so the mm for me is just to cure my curiosity. I’m sure it’s not a quality unit.
  3. ReelFaster
    ReelFaster
    S.Jersey
    Similar here, I grabbed one cheap on Amazon (Dr. Meter) and use it sparingly.
  4. buzz-saw
    buzz-saw
    Ct.
    Hey Brad , I have the same one you had. Always wondered how accurate it really is.
    I figure if I check wood and it is going down that's good , but not sure if numbers are that accurate? I just use it for a rough estimate.
  5. oldspark
    oldspark
    NW Iowa
    Me too, dont use it much but i think it's more then good enough for firewood use. Bttenkiller tested one compared to an expensive unit used for furniture making and said it was fairly accurate.
  6. Biddleman
    Biddleman
    River Hills of Pennsylvania
    I have a cheapie. Figure 2-3% difference in actual reading.
  7. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I think moisture meters are pretty much useless for testing firewood and are a waste of time and money. They are designed for boards not 8” thick pieces of firewood. Sorry to be “that guy” but I’m grumpy today, :doh::rofl: :lol:
  8. oldspark
    oldspark
    NW Iowa
    I'm grumpy everyday but doesn't change the fact they can be useful in some situations.
  9. Jack Straw
    Jack Straw
    One good use I can see is if you buy “ seasoned” firewood and you measure the moisture of the firewood when it’s delivered to use as a bargaining chip to the delivery driver.
  10. ReelFaster
    ReelFaster
    S.Jersey
    This and dead standing I'll use it on just to get an idea. I mostly use father time as a guide......
  11. oldspark
    oldspark
    NW Iowa
    You guys nailed it, buying "seasoned" wood and dead standing. Sometimes i like to monitor how the drying process is going.
    IMHO it has never gave me an inaccurate reading.
  12. Horkn
    Those Dr meter ones are kinda pricey at $50. That said, they get tested against the really expensive ones that are a few hundred dollars and they give the same reading. I like mine.
    buZZsaw BRAD I like the Ryobi phoneworx one that uses your phone. Plug it onto the headphone jack and then your phone is the display.
    Like 20-25 bucks at home Depot.
  13. Horkn
    That's what it really only needs to be for our use. A MM is still the only way of knowing the actual MC of wood. Otherwise you're just making an educated guess, based on how long it's been drying.
  14. oldspark
    oldspark
    NW Iowa
    "This and dead standing"
    That describes me some days.
  15. ReelFaster
    ReelFaster
    S.Jersey
    I paid $13 for mine on Amazon, now it could be a complete knock off of the real Dr. Meter I wouldn't have a clue I was just buying a cheap one and just happened to be Dr. Meter.
    T.Jeff Veal, Horkn, FatBoy85 and 3 others like this.
  16. farmer steve
    farmer steve
    top of the hill york co. PA.
    Brad I use one by general. Lowe's about $20. bear 1998 and I compared his and mine and they were only about 1% difference +/- in readings. I forget what brand his is.
    T.Jeff Veal, Horkn, FatBoy85 and 5 others like this.
  17. Slocum
    Slocum
    North Central Indiana
    I will own one as long as I’m able to process wood. Ive had mine prove me wrong to many times. I have the dr meter. I’m 4-5 years ahead but I still like knowing what the moisture is.
  18. billb3
    They are designed to measure the moisture content of a specific cellulosic material often referred to as 'wood', whether that wood be in the form of a board or a split open log. Some have a switch to also be useful to measure drywall.
  19. farmer steve
    farmer steve
    Mine has a switch to flip to test masonry. Why you would want to do that I don't know. :rolleyes:
  20. billb3
    Most masonry is inherently porous. Concrete is often painted with a sealer on the outside where it will come in contact with soil as a moisture barrier so the concrete walls won't be wet and clammy inside.
    You might not want to paint, say, concrete block wall if the mortar hadn't dried yet, or if the blocks themselves had been subject to a lot of rain previous to or during construction.
