Moisture Meter Calibration Kits. I have put together kits to check your moisture meters calibration against published charts. You get 2 resistors, one is 1Mohm, the other 10Mohm. According to the chart on page 6 of this document, a meter calibrated for Doug Fir at 80 degrees with pins 1.25 inches apart should read a little over 22 at 1Mohm and between 16 and 17 at 10Mohm. These 2 resistors should give you a good idea as to if your meter is reading reasonably. And they will also give you a test point to see if your meter drifts over time. As for my meter. I have a 'fancy' one made in Germany. It even has a built in 1Mohm test resistor in the cap. It reads 27% with the 1Mohm resistor and the test cap, so although consistent I'm not sure what it is calibrated for based on the chart. My wood might be a bit drier than I thought. 25 kits available. I bought 2 small strips of resistors, as shipping was going to be the same for one or 50 and it was still more than the price for the 50. $2.00 in the US. I'll put them in a baggie in a first class envelope and send them off to you.
I think that's a great idea and EXCELLENT of you to offer, Paul bunion You do realize those who buy and those who wonder, will be BOMBARDING you with questions..... Which is all good- you're often sharing sound knowledge on a wide range of subjects, and I really appreciate all you bring to the table. That being said, my cheapie China-zon meter's points are prolly not an 1 1/2" apart, but I'll check it out tomorrow. Right or wrong, I'll be following this thread and digging through the couch cushions for spare coin.
