MillerModSaws plays with a 440R/046D Hybrid
Discussion in 'Chainsaws and Power Equipment' started by millermodsaws, Mar 14, 2015.
  1. millermodsaws
    millermodsaws
    20150319_173914.jpg 20150319_173914.jpg Got her back together again. Not sure what was going down but it's all idling correct now. I ran about half a tank of gas threw her. I will try and get a vid tomorrow. Just jacked around with the comp tester trying to make it work. First was reading 150. Pulled schader cleaned got 170. Changed schrader and got 200. I now this guage is jacked.
  2. FarmHand78
    FarmHand78
    South East Iowa
    Can't wait to see a video... I've read awesome things about 440/460 hybrids.
    Does anyone know if this has been done to a 441/461? I'm guessing the M-tronics wouldn't work right?
  3. millermodsaws
    millermodsaws
    The 441 and 461 are totally different. I'm not saying you couldn't pull it off but most of the reason for building a hybrid is getting the power of a 460 in the weight of a 440. The 441/461 weight about the same. Or that's my opinion. Lol
    mdavlee and Chvymn99 like this.
  4. trx250r180
    trx250r180
    Mine does not run like a 460 ,more like a real strong 440 if that makes sense ,if you have ran both saws a lot you would know what i mean .
    Chvymn99 and Moparmyway like this.
  5. millermodsaws
    millermodsaws
    Here she is. Wanted to see what it would do. 28" bar buried in oak. 7 rim pin, didn't like the 8 with an ok chain. Still running rich for break in.
    Chvymn99 and mdavlee like this.
  6. millermodsaws
    millermodsaws
  7. trx250r180
    trx250r180
    sounds pretty good
    Chvymn99 likes this.
  8. Chvymn99
    :thumbs:.... Sounds good and looks to pull good too!
  9. millermodsaws
    millermodsaws
    It's a start. Lol. Will prob come apart a couple more times.
  10. DexterDay
    DexterDay Administrator
    Northeast Oh
    Sounds great! Seems to pull through that Oak really well!
  11. millermodsaws
    millermodsaws
    O I should a took a pic today. Pulled the rpm after that vid it was running 10500. I leaned it out some it's now running 13500. Much better. Leaned it out to 14000 and ya was very nice. Pulling 205 comp.
  12. millermodsaws
    millermodsaws
    Got here all pulled back down. I'm still not happy with it running. Its weak on the top end. Had a very slight air leak on the comp release. Fixed that. now redueing the carb. Just acts like it's not getting enough up top. Used a torch tip cleaner to mod the 66 jet that's in it till I can get some jets ordered. Hopefully I can run it tomorrow.
  13. trx250r180
    trx250r180
    Make sure the crank seal on the oil pump bushing is not leaking,I have had a couple act like carb problems, I set the bearing on that side with a socket and hammer leak went away saw tuned like it should, May not be the problem but something to look for
  14. millermodsaws
    millermodsaws
    20150324_181454.jpg I ended up boring out the jet size with torch tip cleaners until I get a jet in. Thinking I ended up around a 70-72 jet. Played with the pop off pressure a little bit. I will try and make a vid tonight. It's much better in the way it's acting. Also got my new comp guages. I'm happy with this comp. :dex:
  15. millermodsaws
    millermodsaws
    Ok boys. Got a couple vids. It's pulling much harder now as you will see. The 28" bar vid you can see me plating with the saw dawg in it, pulling it threw and just letting the saw cut the wood. The 24" bar i have the rakers filled to agressively but once I get it going you will see. Lol. Gonna tear it back down now and make some changes but I think once it's going it's gonna be a 24" bar machine and handle a 28" without a problem. Please give me your thoughts. These arnt the best vids as they are me testing. But i 5 ink you'll get what I'm trying to do. Lol
  16. millermodsaws
    millermodsaws
  17. millermodsaws
    millermodsaws
  18. millermodsaws
    millermodsaws
    I want to add. Wood that moves makes for a crappy vid too. Lol.
    MasterMech and Moparmyway like this.
  19. DexterDay
    Northeast Oh
    Yes it does. I feel your pain..
    As for that saw? It sounds great. Runs at a great RPM in the cut.
    Moparmyway likes this.
  20. Moparmyway
    Moparmyway
    New York
    She has alot more oomph now !!
    Looking good !!
    DexterDay likes this.
