Member Designed Saw Is Done
Discussion in 'Chainsaws and Power Equipment' started by KilliansRedLeo, Aug 13, 2014.
  1. mdavlee
    mdavlee
    I think if the 572 or whatever works out the 372 will be ended in a year or so after the release. 576 is a good saw and probably a better saw overall than a 372 but it never got out from under the problems the 575 had.
  2. clemsonfor
    So buy your 372s now and hoard them.
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    There are still non xtorq 372's you can NOS (hasn't been made in several years).
    Which to some, are better than the newer EPA 372 xtorq. But the older XPW was a larger displacement and preferred by a lot of people. They still make a current xpw but they have the same 71 cc displacement as the xtorq 372xp.
    Chvymn99 and clemsonfor like this.
  4. cutforfun
    cutforfun
    Is there any identifing marks on the 51.4mm cylinders that differ from the standard 50mm cylinders, I know some of them had the stamps on the top but those have all been wore off from the cylinders I have.
  5. w8ye
    w8ye
    Mansfield, Ohio
    It's easy enough to measure the bore.
    A metric ruler is good enough or a inch ruler and convert.
    If they are on a saw stick a popsicle stick or pencil in the bore through the exhaust port and measure the mark on it after you've pinched it with the piston.
    mdavlee likes this.
  6. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    51.4mm cylinder castings say W6+++ IIRC.
    DexterDay likes this.
  7. w8ye
    w8ye
    Mansfield, Ohio
    74.7 cc displacement
