Matt's Wood Burning Adventures
Discussion in 'The Wood Pile' started by CtRider, Nov 13, 2016.
  1. CtRider
    CtRider
    Ct
    I found the wires in the basement go to a junction box but then split off and it doesn't make sense. Wish I had a set of those wire testers I had at an old job.
    Anybody know anything about "typical" convection fans?
  2. Horkn
    We had similar ones on the old fireplace chimney at the old cabin. . They had no t stat, just an on/off switch.
  3. Woodporn
    Woodporn
    S. MA
    It looks to be a typical 120v motor, so a line voltage t-stat or a switch.
    Do you have a harbor frieght near you? grab one of those $5 digital voltmeters and check the junction box.
    Horkn, Backwoods Savage and Mag Craft like this.
  4. CtRider
    CtRider
    Ct
    What size do you cut your splits? The previous left me with mostly over 16" which don't fit in the stove very well. Trying to decide if I'm going to trim off a bunch when I restack. It's really a pain not to get enough wood in there for an all night burn cause the pieces are at a 45*
  5. NH mountain man
    NH mountain man
    WMNF N.H.
    I cut 16" to get a full overnight, I burn any longer pieces during the day. Some of my wood is from tree trimmers and homeowners, so I have to work with how they cut it. That leaves me with a smaller piece on a say, 40" log, 40-16-16=8". So those short splits are saved for overnight burning to fit in the mostly full stove. To top it off as they say.
  6. CtRider
    CtRider
    Ct
    Turns out the wire powering the fans was cut and a junction box added and the source now powers some landscape lights that I can control with a dimmer from my living room...ugh.
  7. Woodporn
    Woodporn
    S. MA
    Switch 'em back to the fan for winter??
  8. Woodporn
    Woodporn
    S. MA
    If you want I can draw you a wiring diagram to keep both hooked up and switch off one or the other according to season
  9. CtRider
    CtRider
    Ct
    Not a bad idea - do we think it's worth it? Will they move enough air next to the stove to make a difference or am I better off doing something else? The air channels certainly won't get much heated air from the bricks but pushing air away from the stove seems like it couldn't hurt.
  10. Woodporn
    Woodporn
    S. MA
    I don't know the routing for air, but I'd guess that any air movement around the stove is beneficial
    Is there a plug close by you can test it out with?
    Grab an old crappy lamp cord and wire nut it to the fan leads, see how well it works.....
  11. Kimberly
    Kimberly
    The Kangaroo State
    Do some ebaying or what have you to see if you can get a nice squirrel cage fan to fit in the opening. That fan does not have enough capacity to move the air you need to move.
  12. CtRider
    CtRider
    Ct
    Dumb question - cutting frozen firewood with a chainsaw - does that fact that its frozen dull the chain faster? Is this a no-no?
    Grahamt, NH mountain man and Horkn like this.
  13. Backwoods Savage
    If it does I haven't noticed it.
    NH mountain man, Horkn and yooperdave like this.
  14. Woodporn
    Woodporn
    S. MA
    I'm gonna go with a no.
    Sent from my Pixel using Tapatalk
  15. Woodporn
    Woodporn
    S. MA
    CT, do you want a wiring diagram?
    Backwoods Savage and Horkn like this.
  16. yooperdave
    Cut away CT matters not whether the wood is cold or warm. Matters only if it is dirty or clean.
    B.Brown, Backwoods Savage and Horkn like this.
  17. Horkn
    Some people seem to think so, but I do most of my cutting when it's below freezing. I've not seen any difference in chains dulling faster in freezing temps to above freezing. . You just need to assume that under the snow is a rock.
  18. CtRider
    CtRider
    Ct
    Thanks but I should be ok. When I get some time I'm going switch them back and see how much air it moves to see if it's worth putting in a switch.
    Do you think that a normal circuit could ha for the (6) little walk way lights and the two fans? I would think so but who knows.
    Horkn and Backwoods Savage like this.
  19. CtRider
    CtRider
    Ct
    Awesome. Thanks guys
  20. Woodporn
    Woodporn
    S. MA
    It definitely should......but who knows what else is on the circuit.!
    Shut the breaker off, see what else goes down. (If anything)
    Grahamt, Horkn and Backwoods Savage like this.
