man vs. machine
Discussion in 'The Wood Pile' started by Got Wood?, Feb 6, 2014.
  1. Gark
    Gark
    SW Michigan
    That is a good way to say it.
    I still use both. Popping rounds with the maul and with the 22-ton both have their rewards.
    Got Wood?, tfdchief and raybonz like this.
  2. Carbine
    Carbine
    x2, well put
    Got Wood? likes this.
  3. thistle
    thistle
    Polk/Guthrie Counties,IA
    couple pieces from 15" Hickory snag about 1 month ago....Not real big but was pretty gnarly.X27 bounced a few times,then I got serious :D
      File size:
      148.7 KB
      2
      File size:
      155.6 KB
      2
      File size:
      136.6 KB
      3
    WeldrDave, Got Wood? and raybonz like this.
  4. raybonz
    raybonz Moderator
    Carver, Mass.
    Save some of that for the grill .. You won't be sorry you did!
    WeldrDave and thistle like this.
  5. thistle
    thistle
    I got tons of the stuff....I keep some smaller (1" to 2" branches,slivers from splitting,other scraps) pieces for cooking,all the big stuff helps heat the house.Once in a while I get a few pieces nice enough for woodturning/other crafts,but its very hard to dry without major cracking/warping due to its density.
  6. tfdchief
    tfdchief
    Tuscola, IL
    Yep, me too, for many years! Wish I still could, but now my son handles the Monster Maul and me the 22 ton with a handle :)
    Mitch Newton, Got Wood? and raybonz like this.
  7. gmule
    gmule
    Conifer Colorado
    I use both methods. Sometimes I just feel like whacking some logs and other times I just want to get the job done. Either way is effective.
    tfdchief, Gark, raybonz and 2 others like this.
  8. lukem
    Gum is good for...well....nothing...unless you count frustration. Splits like chit and burns even worse.
    Gark, raybonz and Got Wood? like this.
  9. bogydave
    I hand split at moose camp
    Only because the splitter is to big & heavy to load in/out of the jon boat to get it to/from camp . LOL :)
    Stack of birch in picture, some spruce under the cook tarp
  10. Got Wood?
    Got Wood?
    Amarillo, TX
    Really enjoying all the info and technique from all you guys. Keep it coming. Wealths of wood knowledge.
  11. Joe
    Joe
    Mesick, MI
    I hand split. With my X27 it's pretty quick work. If I had the money to buy a splitter, I'd spend it on saws instead- I have CAD to treat!
    Gark, raybonz, Chvymn99 and 1 other person like this.
  12. Ram1500withanaxe
    Ram1500withanaxe
    I was new to this world after sandy hit us, I ended up splitting 3 cords and ended up with tendinitis, so I got the Huskee 22. I really like the fact that I can pull out the 22 whenever I want and work as long as I want, I've always had limited time to split. Now the pain has disappeared I can do by hand or machine depending on my mood. I tell you though, I lost 15# when I was splitting by hand...
  13. gmule
    gmule
    Conifer Colorado
    What kind of meat do you have hanging?
  14. Blue Vomit
    Blue Vomit
    MD via PA
    I own 1/4 share of a splitter. I went in on it with 3 other close neighbors. When the splitter is down due to a number of reasons to include squirrel eating the plastic gas tank, neighbor flipping it upside down while backing up, general maintenance, etc, I split with the caveman maul.
    When the splitter is up and running, I use it.
  15. bogydave
    moose
    Can' go back & edit
    Cropped the pic
    Better ?
  16. gmule
    gmule
    Conifer Colorado
    I have never ate moose. Is it similar to elk?
  17. Ram1500withanaxe
    Ram1500withanaxe
    Is that 4 legs or the whole thing, if only 4 legs do you do something with the rest?
  18. KatwillNY
    KatwillNY
    Hand split. X25 and X27. Trusty 8lb maul
  19. ansehnlich1
    ansehnlich1
    Here's my 3 pt heavy duty wood buster, run around with it hangin' off the old ford tractor, vertical/horizontal use.
    I also use a fiskars, regular axe, sledgehammers, wedges, splittin' mauls, chains, ropes, pocketknives, cusswords, etc....
    4233285185_b63ed271ac.jpg 4233285995_13e633de53.jpg 4233163355_5587921b18.jpg
  20. bogydave
    Similar
    + couple hundred pounds of neck, back-strap, fillet, heart & ribs in meat bags
    8 lb maul at camp& it's in the P/U when out cutting,, just in case it's needed.
