Making the Right Stove decisions
Discussion in 'Modern EPA Stoves and Fireplaces' started by Old Nate, Jul 12, 2022.
  1. Hoytman
    Hoytman
    OH
    Actually, I was mostly recalling that experience with the “summers heat”, but I also did recall and confused it with the Drolet. I remembered it not having the horsepower you wanted/needed. Thanks for the clarification.
    By the way, just the other day on a forum a manufacturer’s rep actually said what you did…that “their stoves” and modern stoves in general typically do not have the HP of pre-epa stoves. Now he said that “in general” and not as a whole for modern stoves. Meaning some may heat nearly the same, but they are few. He even went as far as to say that “his stoves” would not throw nearly the amounts of heat like “xyz” plate stoves did, actually calling both stoves by name. That plat stove be a compared in the conversation. I also happen to think he was referring to a few of the better plate stoves in general. Not to hard to figure out which ones.
    Cold Trigger Finger likes this.
  2. brenndatomu
    Just FYI, ESW is now owned by SBI, parent company of Drolet...happened within the last year or so...IF that model still exists, I'm sure the QC issues have been dealt with.
    Chvymn99 and Hoytman like this.
  3. chris
    chris
    SE WI
    wow that was a news flash to me that Englander is now part of SBI.
    Chvymn99 likes this.
  4. Hoytman
    Hoytman
    OH
    Yeah I had forgotten about it.
  5. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    Our woodstove is our most important appliance in our house
    We heat solely with wood for 8 months a year. And yet, I'm not a stove nut. No disrespect intended in anyway !
    Our current stove isn't really anything to write home about. It is warped from being overheated too many times. It barely keeps the house warm with an overnight load.
    But, it works. It's an old fashion barrel ish design . Not really big enough for this house. We had the stove and used it for several years before we moved and I built this house.
    I am hoping to get a Blaze King Princess . Even tho that stove is rated for more square feet of house than we have. I do not know what outside temps , woodstove ratings are created for.
    I am looking for Long burn times, plenty of heat, a flat top for cooking on and clean enough emissions the if the smoke nazis ever do arrive here we will be gtg.
    I am thinking to move the stove to a more central location in the house by about 14 feet and eliminating the chimney thru the roof.
    I HATE holes in my roof and did one to save $700. I will Not do that again !
    theburtman and brenndatomu like this.
  6. chris
    chris
    SE WI
    Always can make small fire in big stove to not cook yourself out, pushing a small one never works out in the long run.
    Chvymn99 and theburtman like this.
  7. SD Steve
    SD Steve
    South Dakota
    Whoa, too rich for my blood.....
  8. Old Nate
    Old Nate
    Western PA
    Yeah man I agree, but that’s what all these new ones cost now. Maybe Lowes sells cheaper ones, but they’re just that, cheap.
  9. dennish
    dennish
    Nor Cal
    Drolet is probably one of the best quality lower cost stoves.
    brenndatomu likes this.
