Making grilling "grate" again
Discussion in 'The Smokehouse' started by Eggshooterist, May 22, 2024.
  1. JimBear
    JimBear
    Better sleep, less indigestion & stuff.
    If I eat after about 7:00, I don’t sleep as well & often get indigestion or heartburn. 5:00 is just too early for me.
    Popcorn is my nemesis in the winter.
  2. Eggshooterist
    Eggshooterist
    Erff
    I got my accessories installed today. Folding side shelves and the Next level cooking / indirect heat kit. Two ceramic plates and two stainless grates. They can be used together or mix n match. The whole shebang rotates so you could smoke a steak then spin it over the coals to sear.
    signal-2024-11-18-15-47-11-380.jpg signal-2024-11-18-16-33-06-825.jpg signal-2024-11-18-15-18-12-258.jpg signal-2024-11-18-15-18-22-517.jpg
  3. JimBear
    JimBear
    Looks a nice unit , I hope it works well
    BUT
    It’s not for me , I have already broken one of those ceramic plates just looking at it…
  4. Eric VW
  5. Eggshooterist
    Eggshooterist
    Erff
    I hope I don't break one. They are around 5/8" thick. Pulled pork attempt #1 will be happening before to long now that I have the ability for indirect heating.
    metalcuttr and JimBear like this.
  6. Eggshooterist
    Eggshooterist
    Erff
    Thanks bud. I love this thing.
    metalcuttr, moresnow and Eric VW like this.
  7. Eggshooterist
    Eggshooterist
    Erff
  8. JimBear
    JimBear
    I cooked a couple pounds of bacon on the grill this morning so I didn’t stink up the house. Does that count ??
  9. Eggshooterist
    Eggshooterist
    Erff
    Certainly. It's how I cook all the bacon anymore. In an SnS grills cast iron griddle in the traeger.
    Drip 'N Griddle Pan - 22
    eatonpcat, metalcuttr and JimBear like this.
  10. JimBear
    JimBear
    Looks like a gooder, I may have to request one. Currently I just use rectangle pizza pans.
  11. Eggshooterist
    Eggshooterist
    Erff
    I think I got it on sale. Can't remember. It's pretty deep to hold plenty of pop corn popping grease from the bacon.
  12. Eggshooterist
    Eggshooterist
    Erff
    I forgot all about this thread. I have updates. Still loving the Spider Grills Huntsman but, until recently, there were a couple irritating things about it. One was complained about enough by most buyers that they made an accessory to fix it. More on that in a bit. Issue one... lid didn't open far enough. I contacted them and they said its designed that way so it can't tip over if opened to far. The lid is really heavy and has an adjustable spring lift assist hinge, so I see their point. Why I hated it like this is because it always rolls the smoke right into my face when opening the lid, even with the fan on pause. So I finally put my mind to changing this on my own. Me being a midget put my mirror breaker right at the perfect level for the smoke to get me. I figured if the lid can open farther, the smoke can go up instead of at me. Well, after studying the mechanics of the hinge I was able to go from this opening... 20250917_094118.jpg
    To this opening. 20250917_094159.jpg This without any adverse safety issues. It doesn't feel anymore tippy than stock. Now the lid will upen beyond the centerline of the cooking surface allowing smoke to rise easier. Below shows the bolt that holds in a pin that is a hard stop. I removed it, tightened up the adjustable spring assist just enough to get it to fully open without springing up rapidly. I could elongate the slot in the hinge, that the pin rides in, to still give it a hard stop at the new height, but I feel its unnecessary. Just use a litte common sense when opening it. 20250917_094127.jpg
    The other issue was its low cooking surface height. As a midget, it was still to low. Most buyers complained so they came out with a 3 inch lift kit. Reasonabley priced. Noy it has a taller cooking surface than my traeger pellet grill. Im a happy camper. 20250917_094255.jpg 20250917_094308.jpg
    Eckie, Chvymn99, metalcuttr and 2 others like this.
  13. Eggshooterist
    Eggshooterist
    Erff
    Opening from side view before...
    And after...
    Much betterer. Lol
    Eckie, JimBear, Chvymn99 and 3 others like this.
  14. Eggshooterist
    Eggshooterist
    Erff
    But wait, there's more. We bought this little gem for camping trips and, for a bit, I was using it for small cooks at home. I have something on the way to dedicate to that task, so this unit is strictly a travel grill as it was intended. Its a Weber Go Anywhere. The updated unit with split cooking grates and a charcoal damm for offset cooking. It has those vents on both sides and they can be angled when open so only one end is drafting. Two lid vents facilitate the offset cooking method in conjunction with the side vents. Everything needed to use it except the charcoal fits inside. We keep it and a sealed 5 gallon bucket in the trunk of the truck when traveling.
    20250917_110402.jpg 20250917_110421.jpg 20250917_110432.jpg 20250917_110449.jpg 20250917_110455.jpg
    That's all I have until the other grill arrives. I think my wife is seeing a pattern here. One of anything I "collect" isn't enough. Lol
  15. eatonpcat
    I suppose I will be cancelling my FHC membership...If you guys are gonna start making fun of yourselves, I have no reason to participate! :(
    Eckie, JimBear, Chvymn99 and 4 others like this.
  16. Eggshooterist
    Eggshooterist
    Erff
  17. Eggshooterist
    Eggshooterist
    Erff
    Here we go peeps.
    20250919_094104.jpg 20250919_094109.jpg 20250919_094113.jpg 20250919_094118.jpg 20250919_094135.jpg 20250919_094140.jpg
    eatonpcat, Skier76, Chvymn99 and 2 others like this.
  18. Eggshooterist
    Eggshooterist
    Erff
    Cherry amongst the coal. 20250919_091411.jpg 20250919_102315.jpg 20250919_102215.jpg 20250919_102219.jpg
    eatonpcat, Skier76, Chvymn99 and 3 others like this.
  19. Eggshooterist
    Eggshooterist
    Erff
  20. Eggshooterist
    Eggshooterist
    Erff
    Last one. No need to babysit. The app keeps me informed. Back later. Screenshot_20250919_104818_Spider Grills.jpg
