Making a depth gauge/raker grinding fixture
Discussion in 'Chainsaws and Power Equipment' started by Kevin in Ohio, Dec 9, 2015.
  1. Moparmyway
    Moparmyway
    New York
    There is no "perfect angle" ........... it varies by wood type, what saw is used to cut, how hard you want the chain to bite, and how long you want the cutter to last
    Asking for a sharp fast cutting chain usually means the cutter needs to be sharpened sooner
    Asking for a durable cutting chain usually means the chain isnt as fast cutting as it could be
    There are trade offs that have to be considered for the angles you are looking for
    Kevin in Ohio likes this.
  2. Kevin in Ohio
    Kevin in Ohio
    That makes perfect sense. I'm just a wood cutter for heat but do cut more than most. I like a fast cut but don't need a race chain that only lasts a few cuts. I may still play around with an old chain just for grins though if I get bored.
    Just as a ball park guess. 40 degrees on the top and 10 degrees on the back cut?
  3. Moparmyway
    Moparmyway
    New York
    Top plate of 20 deg on a square cutter is a good start.
    Here is an aggressive squared .404
    Getting the inside top corner to the inside lower corner leaves a pretty sharp and durable cutter, and is a great starting point. You can play with any and all the different angles from there
  4. dgeesaman
    dgeesaman
    Elizabethtown, PA
    concretegrazer and Kevin in Ohio like this.
  5. Gunn
    Gunn
    Plover, Wi
    Here's Oregons angles for reference.
  6. Eric VW
    If a fella could make a rig to do it, it would be built by Kevin in Ohio :thumbs:
  7. Kevin in Ohio
    Kevin in Ohio
    Thanks guys. That is the info I needed to get some ideas. Surprises me that the raker is set at only .025. I guess the this style of sharpening requires more HP to run.
  8. Moparmyway
    Moparmyway
    New York
    Actually, most saws speed up with a good square cutter.
    The cutter is more efficient at severing the wood fibers, so it takes less power
    Another mistake that is made is in thinking that the height for round rakers equates to the height for a square cutters rakers.
    concretegrazer and MasterMech like this.
  9. Kevin in Ohio
    Kevin in Ohio
    Got around to doing all my spare chains (15) today and was asked to show before and afters on a used up chain. This is an 043 Picco going on a 192 rear handle with a 14 in bar. Chain was sharpened and the rakers had been flat ground by hand prior to grinding and were a little varied but had at least .020 depth. most were .025. Sawed first and it did okay but chattered some.
    Before
    After
    Before
    After
    Before
    After
    Before
    After
    When it was done Test running the saw yielded hardly no bounce and chips were nice and consistant. Even with a pretty used up chain it was cutting like new again. One thing With this chain the finish number was .018 deeper than a 2 time sharpened chain.
    I also have noticed how varied the factory stampings are. That really surprised me. When I say that I mean how sometimes the wheel will only take stock off one side of the 2 halves. It's straight but it made me wonder. Some chain runs seem to be a little different so maybe its a die wear thing or different supplier.
    Moparmyway likes this.
  10. Mag Craft
    Mag Craft
    South East Wyoming
    I have a Timberline grinder also. But I took the widest wheel and dressed it to the shape of the rakers and set the head straight up to zero and use it for my dedicated raker grinder. It leaves a very good shape to the raker and is very consistent from raker to raker.
    Kevin that is some very nice work and some very nice equipment. Thanks for sharing that it is very impressive.
    For square grinders you can google Simington grinders he used to have a web site that showed his square grinders and how they were set up. It might give you an idea on how to build your own or modify something already existing.
