Makin' sawdust
Discussion in 'The Sawyer Room' started by Sawdust Man, Oct 27, 2022.
  1. Eric Wanderweg
    I've seen quite a few with grain so twisted you could see a candy cane pattern along the outer bark, but never one side of the trunk completely rippled like that. That is unique. It might be the result of growing on a slope and dealing with winds.
  2. The Wood Wolverine
    Wonder if it would look like flame birch.
    (not my boards) Could be very valuable!
  3. Sawdust Man
    Sawdust Man
    I'd say likely it would.
  4. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I’m seeing gun stocks and guitars
  5. The Wood Wolverine
    :makeitrain":makeitrain":makeitrain"
  6. Sawdust Man
    Sawdust Man
  7. Sawdust Man
    Sawdust Man
    Feb 12th.
    Off topic, I know......
    20240212_105911.jpg 20240212_105948.jpg 20240212_105230.jpg 20240212_103510.jpg 20240212_082349.jpg
    John D, MikeInMa, Chvymn99 and 5 others like this.
  8. Sawdust Man
    Sawdust Man
    16' trailer decking. 20240215_120612.jpg 20240215_133907.jpg 20240215_175021.jpg
    John D, Chvymn99, T.Jeff Veal and 4 others like this.
  9. Sawdust Man
    Sawdust Man
    Customer brought in a few loads of logs with plenty PI vines included....I should probably change a hazard fee..... 20240216_105459.jpg
    John D, MikeInMa, Chvymn99 and 6 others like this.
  10. Sawdust Man
    Sawdust Man
    Black walnut. 20240216_114602.jpg 20240216_115653.jpg 20240216_121706.jpg 20240216_123812.jpg 20240217_111645.jpg 20240217_111651.jpg 20240217_132326.jpg
    John D, Chvymn99, T.Jeff Veal and 3 others like this.
  11. Sawdust Man
    Sawdust Man
    Fence wire & nails/staples included.
    I ran dull blades on this job expecting iron deposits on account of them being yard trees.
    20240217_132136.jpg 20240217_125851.jpg 20240217_125859.jpg 20240217_125902.jpg 20240217_125904.jpg
  12. mike bayerl
    mike bayerl
    John D, Chvymn99, JD Guy and 5 others like this.
  13. eatonpcat
    The Black Walnut is beautiful...The hardware in it, not so nice!
    Chvymn99, JD Guy, T.Jeff Veal and 3 others like this.
  14. Sawdust Man
    Sawdust Man
    Yes iron sucks!
    Since I knew these were yard trees I told the customer he was buying all the blades we destroyed, so it didn't really cost me anything.
    Later I'll post some pictures of something I hit thats much worse than metal for sawing upon.
  15. Sawdust Man
    Sawdust Man
    Boxelder.
    Some wow colors in this stuff, I'm not sure how well it will do after it's dry, but sure is dramatic when fresh. 20240217_155700.jpg 20240217_155630.jpg 20240217_160259.jpg 20240217_160305.jpg 20240217_160308.jpg 20240217_160316.jpg 20240217_160322.jpg
    John D, Chvymn99, eatonpcat and 5 others like this.
  16. Sawdust Man
    Sawdust Man
    And a nice porcelain insulator. 20240217_160938.jpg 20240217_160927.jpg 20240217_161242.jpg 20240217_161247.jpg
    After cutting the slab off, I put on a different dull blade and finished the cut.
    Next cut I went until I was real close, then turned it around and came from the other end before sawing through the lag bolt.
    The blade........
    John D, Chvymn99, JD Guy and 3 others like this.
  17. Jeffrey Svoboda
    Jeffrey Svoboda
    That looks frustrating. I always wonder how you guys know what you do when you start hitting metal or other objects. I suppose its just from experience?
  18. Sawdust Man
    Sawdust Man
    Yes.
    Like anything a person does a lot, experience tells us what's likely the best course of action......usually.
    Yard trees are highly risky, so I always ask when a customer brings logs in for milling, that way I can warn em and let em know they are liable for ruined blades.... and what a blade costs.
    John D, Chvymn99, eatonpcat and 3 others like this.
  19. Jeffrey Svoboda
    Jeffrey Svoboda
    Was sitting here thinking and came up with this. Someone probably said it before or it's quoted somewhere.
    Experience is more about knowing what not to do rather than knowing what to do.
    Chvymn99, eatonpcat, JD Guy and 2 others like this.
  20. Sawdust Man
    Sawdust Man
    Yep, that pretty well sums it up. :yes:
    Chvymn99, eatonpcat, JD Guy and 3 others like this.
