Makin Kindlin.........
Discussion in 'The Wood Pile' started by Well Seasoned, Oct 4, 2015.
  1. Well Seasoned
    Thanks Woody!
    The boss just agreed.
  2. firecracker_77
    firecracker_77
    IL
    I use the Supercedars and lumber cut offs. With dry wood, it's a sure fire method.
  3. ChuckinMichigan
    ChuckinMichigan Banned
    Southeastern Michigan
    Not always true. With stoves like the Woodstock soapstone progress hybrid, you have to build a kindling fire to bring it up to about 200° or 250 degrees and then you have to add your splits and then enable the cat you can't go from 0 to 700 on that stove. because if you do you'll mess it up. it says that in the manual.
    Well Seasoned likes this.
  4. rdust
    rdust
    SE, Michigan
    Non sense, Woodstock stoves are darn near bullet proof! :) The PH is a steel stove with soapstone on the outside, it's not constructed like a Fireview or their other soapstone stoves that have two layers of soapstone. I'm not sure how taking it to 250 then adding splits changes anything other than establishing a nice coal bed to load full size splits on top of. When you load it full of splits it will go past 250 on it's way to it's final temp. :)
    ChuckinMichigan likes this.
  5. rdust
    rdust
    SE, Michigan
    It's soapstone lined, that's it, the firebox is steel. I'll find the info for you so you know how your stove is actually made. :cool::rofl: :lol:
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    LOL!!!!!!!!!!!!:heidi:
  7. rdust
    rdust
    SE, Michigan
  8. ChuckinMichigan
    Okay... Okay... I was mistaken. I thought the PH was made like the Fireview.
    I don't own a PH yet. I hope to, one day!
    That explains why the thing puts out the heat. Steel, with soapstone with the iron too.... No wonder. :eek::jaw::bug:
    My apologies. :emb:
    But, that manual says do not go from cold to raging fire... obviously for good reasons. o_O
  9. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    at least you fessed up sally.
  10. ChuckinMichigan
    :p
  11. Scotty Overkill
    Play nice, fellas.......a little sarcasm is good for ones soul, on BOTH ends...... ;)
    Hey, we here at FHC support Super Cedars, they've been with us since day one. But I make my OWN starters and kindling, always have. It's a matter of personal preference. Plus I get all kinds of cedar and sappy pine heartwood so it's convenient and even FUN for me...
    Ashwatcher, Eric VW, raybonz and 3 others like this.
  12. ChuckinMichigan
    Sorry about that. I thought the PH was made like the Fireview. Guess not! :doh:
    But, no wonder that monster puts out the heat! Steel with soapstone and iron too? Yeesh, be lucky to burn like 6 pieces of wood without running one outta the house! :jaw::bug::eek:o_O:campfire::MM:
  13. Well Seasoned
    Water under the bridge. Wheres the snow?
    Eric VW, raybonz and ChuckinMichigan like this.
  14. ChuckinMichigan
    It can't snow yet, the leaves ain't fell off the trees around here yet! Speaking of that, Mom turned the A/C back on here... :picard:
    The weather business around here is kinda lo lo if you ask me. :loco: :crazy:
    raybonz and Well Seasoned like this.
  15. Well Seasoned
    My central air kicked on the other day I had the stove going. Boy did I run!
  16. ChuckinMichigan
    unclefess likes this.
  17. Backwoods Savage
    Well, sometimes you can forget things that are printed in manuals. That definitely is not how we start our fires in our Woodstock stove! And no, we've not messed it up yet. We are starting our 9th year with the Fireview. So far, we've changed one gasket. End of maintenance.
    But I agree, you do not want to take that stove up to 700 degrees from a cold start very quickly.
