Makin' an all black JRed
Discussion in 'Chainsaws and Power Equipment' started by The Wood Wolverine, Dec 27, 2016.
  1. The Wood Wolverine
    Spray a lil carb cleaner around the intake and carb. If it gets sucked in, it will make idle stumble a bit.
    Messaging you now...
    Hammy and Kyle Mulligan like this.
  2. Duane(Pa)
    Duane(Pa)
    Centre Co.
    Use wd40. Won' attack rubber and paint like carb cleaner does.
  3. ECsaws
    ECsaws
    That's how I would do it
  4. Kyle Mulligan
    Kyle Mulligan
    North Greenbush, NY
    So run the saw. Spray wd40 around intake. If any leaks the saw will suck in and stumble or stall. If the intake is sealed then continues to idle with no change.
    What about around the base of cylinder, decomp valve or clutch side seal? Works the same?
    Hammy likes this.
  5. DexterDay
    DexterDay Administrator
    Northeast Oh
    I have a saw that could be dyed black!!
    But that's up to you and if you want to do it.
    Love the look of the black saw! Pretty. Awesome!
    You and your son are a great team!
