Maiden voyage
Discussion in 'The Sawyer Room' started by bocefus78, Aug 13, 2016.
  1. bocefus78
    bocefus78
    Indiana
    No. I used straight oil. Should I be cutting it?
    Eric VW and Shawn Curry like this.
  2. Shawn Curry
    Shawn Curry
    Western NY
    Yeah - I like to thin out my bar oil with about 1/3 ATF for milling. It helps keep the links oilier for the long round trip through the cut.
    If you're going to use an aux oiler, I'd use straight bar oil in there. But, you may find you don't need it if you thin out the oil.
    schlot, Eric VW and bocefus78 like this.
  3. mike bayerl
    mike bayerl
    Hmmm... I would have thought all 90 cc saws already had ho oilers. Also, I would have thought that thicker, undiluted oil would stay on the bar and chain longer. Hard to argue with real world experience.
    schlot likes this.
  4. Shawn Curry
    Shawn Curry
    Western NY
    When you're crosscutting, you're doing most of your cutting with the bottom of the bar; so a sticky oil helps to keep it from slinging off when it rounds the tip. When you're milling, the bar stays "buried" the entire time, dragging both sides of the chain through the cut. If the oil is "sticky" it gets rubbed off quicker.
    It's not my trick, I learned it from "Chainsaw Lumbermaking" by Will Malloff.
  5. bocefus78
    bocefus78
    Indiana
    Ok, now I need to go start a thread titled "which ATF to use to thin my bar oil" and see how many pages of stupid responses I can get :rofl: :lol:
    I lied, save me that trouble. Do I just use the cheapest stuff I can get? Dexos? DexronIII?
    Thank you!
  6. bocefus78
    bocefus78
    Indiana
    I stihl haven't read that book, but it's hard to argue with that level of experience.
  7. Scotty Overkill
    Chainsaw milling is certainly fun, but it's definitely laborious and messy.
    One thing I've found that can make it a little easier is to lay a tarp on the ground on the discharge side (aka the powerhead side). Every two passes or so, pull the tarp and dump it somewhere. Makes for easier cleanup....
    schlot, thistle, Eric VW and 2 others like this.
  8. bocefus78
    bocefus78
    Indiana
    Love it. 9 dollar tarp. Million Dollar idea. Sometimes the easiest solution escapes us.
    thistle, Scotty Overkill and Eric VW like this.
  9. Boomstick
    Boomstick Banned
    Saratoga county ny
    I've seen it cut with diesel and home heating oil, both cheaper than atf.
    Its like a winter bar oil but thinner.
    My band mill only turns 3800fps+- and I mix 50/50 bar oil and home heating fuel. Keeps costs down, best lube combo ive used yet.
    A good atf I'm sure has much better lubrication/shear qualities compared to kerosene diesel etc. but I doubt people use the 7-9$ a quart stuff anyway.
    schlot, Shawn Curry and mdavlee like this.
  10. bocefus78
    bocefus78
    Indiana
    My buddy is a mechanic. He saved me a gallon from the last trans flush he did. Is used ATF ok to use Shawn Curry?
  11. Shawn Curry
    Shawn Curry
    Western NY
    I've never tried that, but I'm not too picky about the ATF I use - I just get whatever's cheap or at the store when I need some. I imagine it would be fine, just dirtier. I suppose what precisely is in that dirtiness could be a concern. Suspended metal bits in the trace amount of oil left on the lumber, if not removed during surfacing, could rust under a finish. When I Googled it, I found a bunch of stuff about using as a diesel substitute, so I suppose it can't be that bad?
    mdavlee likes this.
  12. mdavlee
    mdavlee
    Staining the wood will be my only concern. Sort of like using used motor oil.
