Mahindra 4540 4WD
Discussion in 'Chainsaws and Power Equipment' started by thewoodlands, Aug 3, 2016.
  1. thewoodlands
    thewoodlands
    It looks like tomorrow will be a rainy day so it might be a good day to burn.
    I hope the socket set will last my lifetime. I see that you received your tractor back, I hope that's the last of your problems.
    Backwoods Savage and Gasifier like this.
  2. yooperdave
    Just as in poker, a straight flush beats a full house!
  3. Gasifier
    Correct on the rain. And it is a good day to burn. That's for sure!
    As far as the tractor problems go. Thank you. It is a nice piece of equipment when all is working well. Just been way to many days when it hasn't been for a new tractor. Time to keep moving forward.
  4. thewoodlands
    thewoodlands
    I use the tractor to move some Maple rounds and then to dig up a few smaller stumps from our winter plow zone.
    Thor, Chvymn99, Hammy and 4 others like this.
  5. Backwoods Savage
    thewoodlands and Gasifier what is the width of your buckets on the backhoe? I think we will definitely get a backhoe before next summer and not sure what size to get. Thinking 16".
  6. Gasifier
    I went with a 24". I plan on doing a good bit of ditching and then using that soil to fill in low spots in nearby trails. So I figured a little bigger capacity would be gooder.
  7. thewoodlands
    thewoodlands
    I think ours is 16, I'm not sure if we'll go to a 24 or not.
    Backwoods Savage and Hammy like this.
  8. thewoodlands
    thewoodlands
    I removed two smaller stumps and then grabbed some sand to fill in the holes. I switched to the pallet forks and then removed two loads (one pictured) over near the fireplace for burning.
    We had decided this morning that since I would be burning, we would have steaks cooked over the outside fireplace.
  9. thewoodlands
    thewoodlands
    The steaks, we also had a baked potato,hot tomato salad and spinach.. 100_0600.JPG
  10. Gasifier
    :drool:
    Chvymn99 and thewoodlands like this.
  11. Gasifier
    Nice work there our friend. A tractor is sooooo nice to have. They multiply your production by ...............
  12. brenndatomu
    We find ourselves most often using the 18" on the Case 580 at work...we have 12", 18", 24" and 36" for it but that is a much larger machine too. I'm surprised that small of a tractor handles anything more than 14-16" very well...
  13. Gasifier
    My 50 horse tractor with the 75B backhoe digs and pulls stumps very well for this size machine. I'm not sure what size backhoe Backwoods Savage will put on his tractor. But his tractor size will pretty much determine how big a backhoe he can go with. Something else to consider with bucket size is what you will do most of. If looking to dig a lot of stumps some say it is better to have narrower bucket, that you can rip the roots apart easier. I know a guy who had a very narrow one made up for his mini excavator just for that purpose. Almost like a very heavy, curved blade. He can use it for digging a narrow trench, but it is used mostly for ripping stumps out. I can rip stumps out with my two footer just fine as well. A smaller backhoe may not have enough strength.
    Backwoods Savage and brenndatomu like this.
  14. thewoodlands
    thewoodlands
    I have just used our last five gallons of summer blend diesel so I always email Sunoco just so I can make sure the winter blend diesel has made it to this area, it has.
    This was his response, Winter diesel blends have been rolled out in that area, yes.
    Thor, Backwoods Savage and Gasifier like this.
  15. Backwoods Savage
    One also needs to consider what he will be digging in. If we had heavy ground I probably would not consider anything larger than a 12" but with our really light sand, I should be able to handle much larger.
    Hammy likes this.
  16. thewoodlands
    thewoodlands
    After getting some diesel after dog sitting, I grabbed a small load of branches that I burned down but have some smaller stuff left.
    I would've finished burning the rest but supper was on the table.
  17. thewoodlands
    thewoodlands
    I saw my model tractor with a three foot bucket on the hoe ( I don't think they recommend it) he busted the frame the hoe sits on. I'm not sure if it was covered under the warranty because of the oversized bucket on the hoe.
  18. yooperdave
    I bet not.
  19. thewoodlands
    thewoodlands
    This is the area we started clearing out in the spring because the trees are rotting from the stump up because of all the water it gets every spring once the snow melts. We dropped four smaller trees and then took the rounds to the pine splitting pile.
    The stump was a bastard but I finally got it out along with a smaller one.
    This morning I heard a chipper going across the street so I made my way over. They were glad to deliver them across the road, I'll use them on the trails.
  20. thewoodlands
    thewoodlands
    I moved a bunch of the chips with the 4540 that we received for nothing to part of the trail on the property I cut most of our wood on.
    Gasifier, Thor, Chvymn99 and 3 others like this.
