Mahindra 3550
Discussion in 'Chainsaws and Power Equipment' started by Gasifier, Feb 11, 2017.
  1. Felter
    Felter Banned
    chicago
    sounds like a plan!!! I just hope you don't end up having to jump off the machine and switch the pins every 5 min. either way I would like to see a build thread of that project. :thumbs::whistle:
    Blazing, concretegrazer and Gasifier like this.
  2. Felter
    Felter Banned
    chicago
    also as long as you can lift the "lid" and wiggle it. it wouldn't be hard to switch the pins.
    concretegrazer likes this.
  3. Gasifier
    Yup. Will do. I'm not as concerned with it being able to close tight all the time. I have a lot of brush/stump/dead log clean up to do in the years to come. Need capacity :dex:
    Dancan, basod, Blazing and 1 other person like this.
  4. Gasifier
    Here is my :sherlock:Have Grapple on ground. Pull up to grapple with loader bucket or backhoe. Put strap or chain on lid, take up slack and hold weight of lid. Pull hinge bolts and pin. Raise lid up to higher set of mounts. Align and place bolts and pin in. Should work. I :sherlock:
    Blazing likes this.
  5. Gasifier
    Google is always interesting. Type in adjustable grapple. And I envision something similar to this.
  6. concretegrazer
    concretegrazer
    Southwest MO
    Yes you'll need to operate at a higher rpm than your use to. Part of it is due to the hydro the other is the powerband is higher with this motor. Peak hp is at 2800rpm where with your old ones it was probably down around 2200.
  7. concretegrazer
    concretegrazer
    Southwest MO
    If I'm reading this right I think that'll work good.
    Gasifier likes this.
  8. Felter
    Felter Banned
    chicago
    that picture is worth a thousand words :yes: stupid me, I was picturing something totally different. :picard:I was thinking another cylinder mount on the lid of the grapple. something where you would pull the pin farthest from the seat. then raise the lid of the grapple a couple inches. then put the pin in the new hole. but your idea would open the grapple much farther.
    Blazing and Gasifier like this.
  9. Gasifier
    Ya. I see that on the tach there is an arrow that points near 2500 RPM for PTO peak operation to be at 540RPM.o_O
    savemoney and concretegrazer like this.
  10. 94BULLITT
    94BULLITT
    Frederick County, VA
    Gasifier Does the lid not open 90* on your grapple?
  11. basod
    basod
    Mount Cheaha AL
    Gas might be easier to make the rear cylinder mount taller & pivot with 3 different pin holes.
    I can sketch something and scan it you.
  12. Gasifier
    I would like that! Thanks. I also wonder if a longer hydraulic ram/cylinder would be better.
  13. Gasifier
    No.
    94BULLITT likes this.
  14. basod
    basod
    Mount Cheaha AL
    Kind of what I was thinking
    or make the mount point angled back further and buy a longer cylinder
  15. Gasifier
    :sherlock:
    Felter likes this.
  16. Gasifier
    Aaaaaaa-hem! I haven't smoked a pipe like that in a while! Sorry. :emb:
    Felter likes this.
  17. Gasifier
    This afternoon I went to work directly behind the barn. Forgot to take any pics.:doh: The snow coming off the roof was building up too high. (We had been leaving the snow because it provides traction for the horses, as appossed to slippery, frozen clay.) But now when things started to melt water was starting to run back into the horse stalls. So I used the 3550 and parked where I needed it to use the 75B backhoe to break up all the snow and ice and pull it down away from the back wall of the barn. Surprising just how hard that combination of snow/ice/compacted horse chit can be! o_O Then I used the front bucket and cleared everything away and pushed it over toward the fence. Wife followed up after I was done and raked off some of the broken up clay and manure into larger holes I left. Then I tossed her 6 big feed bags of saw dust from the Amish saw mill into the double stall. She had cleaned the stall all out and pulled a bunch of the old sawdust out the stall doors and spread it all over the ground outside the doors to give them a nice surface to walk on. So she broke all that new sawdust up and put a nice new layer down through out the stall. The horses didn't even say thanks. They just kept eating and pooping.:picard:
  18. thewoodlands
    thewoodlands
    Nice work Gasifier , with the temps getting close to 50 this weekend things will be a mess.
  19. Gasifier
    I see that. I'm going to try to get some things done with the tractor tomorrow while still enough snow here and the ground is still frozen.
  20. clemsonfor
    If I were to buy a new one I would look hard at Manihandra. Nice tractor!!!
