Made my own fire fuel
Discussion in 'The DIY Room' started by The Wood Wolverine, Sep 27, 2021.
  1. Erik B
    Erik B
    Western Wisconsin
    buZZsaw BRAD My dad had one of those too. I believe he used wire to secure each "log". You had to sift thru the ashes to get the wire out after burning. I was not living at home when he was using that thing so I don't know how well it worked.
  2. metalcuttr
    metalcuttr
    western WA
    The second video with the double buckets got me thinking. I have a cider press which I could remove the basket and tray from and substitute a small piece of plywood to place the bucket on. The press screw would bear on the wood plate that he places in the bucket. This would be an excellent way to press out the water just as the third video uses the hydraulic jack!
  3. billb3
    When you run out of newsprint you'll have to try fresh horse manure.
    Or maybe mix some in.
  4. The Wood Wolverine
    No likes from me. :picard: You can add lots of things! Sawdust, leaves, etc.
  5. buZZsaw BRAD
    Seeing since you make lots of noodles have you ever tried it with them? An oak biolog???
  6. buZZsaw BRAD
    I remember helping him roll them. He ran out of wire and used duct tape! :picard:
  7. The Wood Wolverine
    The issue there is, the wood doesn’t get “soft”. So you’d have to mix it at whatever level worked to get compression so the brick would stay tight.
  8. The Wood Wolverine
    Twine would work good. A “country” boy always has some of that laying around. :D
  9. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    Great project ! Did they dry out yet ?
  10. Nitrodave
    Nitrodave
    Grayling Mi.
    We used to make these when I was a kid . Mom would bring home all the papers from the music store … we could heat all winter on just 3 chord of these …. :rofl: :lol::whistle:
    Ok… I’ll show myself out now…:wacky:
  11. buZZsaw BRAD
  12. The Wood Wolverine
    Yep. I checked them out when I got home from vaca yesterday. I’ll be bringing them inside this evening.
  13. The Wood Wolverine
    I see it as a resource I’m not waisting.
  14. MikeInMa
    Have you ever cut one open and used a moisture meter to see what it reads?
  15. The Wood Wolverine
  16. buZZsaw BRAD
    I think you should make a huge one and noodle it! Be an interesting sight for sure.
  17. The Wood Wolverine
    Which way is the grain oriented? :smoke:
    I think moving forward when I do this again, I will convert some 5 gallon buckets for a large puck. I have a shop press as well...
  18. JackHammer
    JackHammer
    I don't have a shop press but I have a splitter...
    Then again, you would need a good quantity of paper to make this worth the effort. I save my paper all year long and it is gone by the spring. Cool project. :yes:
  19. The Wood Wolverine
    Splitter would probably be the better idea so I don't soak the shop press with water. It has wheels too so I won't have to worry there. :thumbs:
  20. Stinny
    "Splitter would probably be the better idea so I don't soak the shop press with water. It has wheels too so I won't have to worry there." Good idea... you might be able to build a sectioned press box, to squeeze 6-8 bricks at a time too. I know splitters work great mulching computers... :whistle::D
