Lucky to be posting this
Discussion in 'The Wood Pile' started by jrider, May 27, 2023.
  1. jrider
    jrider
    Too damm close! We are talking inches on this one. I’m still going over and over in my mind.
  2. jrider
    jrider
    Thank you. Here in flat country that’s not a term we use
  3. Chud
    Chud
    NC
    Roll Over Protection Structure
  4. Erik B
    Erik B
    Western Wisconsin
    Glad you were able to walk away with minimal damage both to yourself and your tractor.
  5. wildwest
  6. FarmerJ
    FarmerJ
    Minnesota
    Glad all is well…
  7. Stephiedoll
    Stephiedoll
    Omaha, NE.
    As everyone else says, glad you are okay. Maybe take the weekend off to calm your nerves.
  8. buZZsaw BRAD
    Holy chit! :bug: Felling those dead ones are scary. Especially that size. Limb shrapnel galore and they break clean unlike living trees.
    Watched the neighbor next to my storage drop a dead white oak and its snapped. All was okay but what a sound.
    Good reminder of the dangers involved in all we do. Glad you and tractor are okay and heal up fast.
  9. thewoodlands
    thewoodlands
    Wash the underwear and get back in the saddle, glad you're okay.
  10. EODDiver
    EODDiver
    Nashville, TN
    I'll be extra careful cutting today. I never feel at ease when cutting down a standing tree due to unknowns.
  11. Backwoods Savage
    Nasty for sure. I hope the leg is not bad.
  12. Biddleman
    Biddleman
    River Hills of Pennsylvania
    Dang. Glad you made it out with just a bruise. chit can happen so fast.
  13. Hinerman
    Hinerman
    NE Oklahoma
    Glad you are ok. No way of ever seeing that coming. Would a longer chain or strap have gotten you out of the "danger zone"?
  14. jrider
    jrider
    I’m still limping but it should be fine.
  15. jrider
    jrider
    It would have taken another 20’ which I will be sure to use at least two if not 3 chains in the future.
  16. Canadian border VT
    :bug: Glad this is a walk away learning lesson!!
  17. moresnow
    moresnow
    This^
    Thanks for sharing. Good info for others to consider.
  18. thewoodlands
    thewoodlands
    We've been taking down some dead pine (13 so far) the tops on the trees are the weakest part so we do indirect pulls. The wife uses the RTV with the winch, a tow strap/tree saver always goes around the tree before I fell it. The tree saver and cable is hooked up to a d shackle, another tree saver goes around another tree with a smaller d shackle that that the tree saver and snatch block hook up to (get your cable through the snatch block first and then the cable finally hooks up to the winch on the RTV. We do indirect pulls so the wife is out of harms way. I can leave a fatter hinge than normal (she has a slight tension on it when I'm making my back cut) once I'm out on my escape route she'll start a nice steady pull.
    In the graphic below A would be the tree, O would be the tree we're felling toward, I use a longer tree saver (keeps the tree you're felling away from the anchor tree) that the snatch block will be hooked to with a smaller d shackle the cable goes through to the winch on the RTV, B would be the wife in the RTV out of harms way.
    Some people on the site will say what I described isn't needed but since they're not felling the rotten pine, I really could care less what they think, that can go for this info too.
    I haven't read all the post but how are you feeling a few days after jrider?
  19. Ronaldo
    Ronaldo
    So glad you came out ok. We just never know when something could go sideways, go we. There is no reason that tree should have broken like that and its certainly not something one would expect. Thanks for sharing and remember to thank God for His care and protection!
    Sent from my SM-G930VL using Tapatalk
  20. JD Guy
    JD Guy
    Upstate SC
    jrider You might want to keep an eye on the “bruise”. Depending how bad and deep it is there can be clots that form and move through your veins. I had that happen to me at a young age but thankfully no I’ll effects, I was given something to dissolve the clots but it’s been 60 years ago :)
