Low budget chainsaw mill ?
Discussion in 'The Sawyer Room' started by Pallet Pete, Oct 8, 2013.
  1. mdavlee
    mdavlee
    The long pieces are 36", the cross pieces are 8", and the uprights are 16". The next one I'll get some 15 series aluminum so I can tap the end for 5/16" so I don't need another piece of angle to attach to the bar. That is 45mm sized tubing and I got it real cheap. If you go with that stuff get the 1 bolt corner brackets or the outside brackets. I got the idea from sachsmo and he sent me the measurements on his. I'll probably make a bigger one if I get a 42" bar.
    Oliver1655 likes this.
  2. mdavlee
    mdavlee
    The mill works pretty good. I do need to locktite all the bolts in it. I had a couple rattle loose on me the other day.
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    So it works well, eh? May have to try and build one. I want to do some milling, but don't have the time to do as much as I would like. But, I would like to make a few benches for around the fire pit. My 460 should suffice For those few cuts.
    As for vibration. .
    I just had the clip on my drum/rim fall off or break yesterday! On my new 441C-M! Hoping it was a fluke, because it only has about an hour of run time.
    Oliver1655 and mdavlee like this.
  4. mdavlee
    mdavlee
    Get the one bolt corner brackets for that stuff if you decide to use it. The 2 bolt are too big for the inside. I'm going to change mine around some here in the next month or so. I need to grab a few more parts off ebay. The 460 should work as long as you're not going over maybe 24" wide. It gets slow with 90cc saws around that much wood.
    DexterDay likes this.
  5. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Why ..all of a sudden...do I think I need one of these now ?? :)
  6. Loon
    Loon
    North of the border
    Was thinking the same thing when i first seen this Fuzz :D
    HoneyFuzz likes this.
  7. swags
    swags Moderator
    me too!
    Got Wood? and HoneyFuzz like this.
  8. DexterDay
    Northeast Oh
    Time for a bigger saw ;)
    Great excuse to buy a 660 :thumbs:
  9. Chity_Avatar
    Chity_Avatar
    I have $18 total invested in this entire set up including the ladder, minus the cost of the chainsaw of course.
  10. DexterDay
    Northeast Oh
    Nice!!! :)
  11. mdavlee
    mdavlee
    Fixed it for you
  12. swags
    swags Moderator
    That's great that you made it and for the price even better!
  13. mdavlee
    mdavlee
    I just assembled the granberg 56" mill this morning. No way I could build it as cheap as thy sell it plus the extra weight.
  14. MasterMech
    56" Mill? o_O What kind of bologna are you slicing?
    mdavlee likes this.
  15. mdavlee
    mdavlee
    Extra thick:popcorn:
    MasterMech and swags like this.
  16. mdavlee
    mdavlee
    Here's the 046 on the mill working on some black walnut.
  17. swags
    swags Moderator
    Did you add an aux oiler?
  18. mdavlee
    mdavlee
    No just the HO oiler for the 46. It is using about equal fuel and oil now.
  19. Terry Goggin
    Terry Goggin
    IRELAND
    I would check out the Logosol timber jig it's cheap and easy to use on any saw
    DexterDay, HDRock and mdavlee like this.
  20. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    So this thread has gotten me a bug, Looks Like I will be picking one up to start making Timbers for some little projects around the property I have been wanting to do. I brew beer, and have been trying to decide how I wanted to build a trellis for growing Hops, and I think this would be great. The long term thought is to build a small Timber frame cabin in Northern Michigan. Something off grid and small, a place to get away.
    Now to build or Buy? Probably Build, y'all are giving me great ideas.
    HDRock, DexterDay and mdavlee like this.
