Looking for advice/recommendations on ZTR's
Discussion in 'Everything Else (off topic)' started by eatonpcat, Jul 30, 2018.
  1. ironpony
    ironpony
    Mid Ohio
    why do you want something that big? (HP) all it is going to do is suck down lots of fuel. Have you eliminated the BADBOY? 5 grand gets you a brand new one, commercial hydros same 3100's the rest use, the rest is welded steel.
    eatonpcat and Horkn like this.
  2. brenndatomu
    My buddy just text me that he is considering buying a new commercial Exmark 54" on sale for $5k...
    Chvymn99, eatonpcat and Horkn like this.
  3. TurboDiesel
    end of summer. time to blow out the leftovers.
  4. brenndatomu
    That's true...I was impressed when I switched from my Toro with a 17 HP single cyl Kohler engine to a Hustler with 20 HP twin cyl Kohler...fuel usage was not noticeably different...power (torque) is up very noticeably though!
    That said...31 HP is gonna use some fuel!
  5. eatonpcat
    I guess I am not looking for that much hp, but if I find what I consider the right mower and it has a big motor...
    Says the man driving the big Cummins Diesel!!
    brenndatomu and Chvymn99 like this.
  6. lukem
    It will only make 31HP if you need it. If the motor isn't under a lot of load, then it burns less fuel. Sure, there's a little more "overhead" associated with the additional displacement, but the difference isn't much.
    I have the same motor on my mower and it probably burns about 1 - 1.25 gallons per hour mowing tall/thick grass in the spring...closer to one in the summer and fall. I can mow full speed year round...the extra power is nice when you need it.
    eatonpcat, Horkn, brenndatomu and 2 others like this.
  7. RCBS
    RCBS
    Over here
    I get away with running 3/4 throttle most of the time and still get a nice cut. At filt tilt...it sounds like I may achieve liftoff. I have high lift blades on it and they are a bit noisy. There is improvement in the quality of cut running full throttle, but I ain't really cutting for show.
  8. lukem
    I always thought you were supposed to run them full throttle for to keep the hydro pumps cool and oil pressure up in the engine. I run 3600 no-load RPM.
  9. RCBS
    RCBS
    Over here
    My mower is a bit different beast as far as the transmission...no Hydro 'pumps'...proprietary HST transmission with 4 gallon capacity. Have never read anything about them getting 'hot' in my readings about the ZD Botas. No tach on my machine, so I assume that there is not a 'set' RPM for mower?
    I haven't the foggiest on most other mowers...possibly? I tend to run equipment only as hard as needed. Some of my friends crank it to the max whether they need it or not. I always figure if they allow you to regulate the throttle...you can do so with no fear of damage, otherwise the machine should come with a static throttle or a handy dandy warning label.
    Just checked my manual. "Operate at full throttle for best results." They want the throttle at 1/2 for engagement of mower...so I figure anything in between is fair game?
    eatonpcat, Horkn and brenndatomu like this.
  10. lukem
    That's a different animal than a gas ZTR.
    bocefus78 and brenndatomu like this.
  11. brenndatomu
    Kinda like the old big block V8s...8 MPG loaded or empty...:whistle:
  12. Eric VW
    Hey eatonpcat, why don’t you shop the price down a little and spend some of the savings on a freakin’ set of stairs.....:D
    :salute:
  13. Horkn
    Lol, some people climb the ladder at work, some people climb the ladder at home. ;)
  14. Eric VW
    As long as eatonpcat don’t have a slew of AB’s and then try the ladder....:drunk:
    :faint:
    :picard:
    eatonpcat, Horkn, TurboDiesel and 3 others like this.
  15. Canadian border VT
    Hey nothing wrong with ladders I got one in barn.. Also a set of stairs to replace when time comes..:whistle:
  16. brenndatomu
  17. ironpony
    ironpony
    Mid Ohio
    But But I NEED 300 + HP and 900 ft.lbs. of torque......................
  18. bocefus78
    bocefus78
    Indiana
    FWIW I have a scag efi 61 velocity deck trade in I just got....located in zip 46060. Lower hours than you are looking at 580 or so....and I know its history. Can be had for less than what you've mentioned eatonpcat
  19. brenndatomu
    Wrong thread Pete? :whistle: :rofl: :lol:
  20. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Wait a minute! Beer....:picard:
